Making your Toyota EV Charging Cable G9060-47190 OEM J1772 Prius Anti-theft ..
Discussion in 'Prime Accessories and Modifications' started by Violet Rose, Mar 5, 2019.
  1. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Thanks for the clarification about the Base model not having the locking button.
    Rob43
  2. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    What is Toyota thinking, no cable lock for plus model? Ridiculous.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,148
    Tampa, FL
    Yup! I see that now that I look at the brochures. You'd think they'd say something like, "If so equipped," in that part of the manual.
    By the way, another method I've seen in the PiP forum is a locking cable run through the spokes of the RR wheel and around the cable snugly enough to keep the handle from going through the loop. That's easier to make, but @Violet Rose's method is definitely easier to use.
  4. Gerlax
    Gerlax Junior Member
    Maine
    2018 Prius Prime
    BRILLIANT. THIS IS FRIGGING BRILLIANT. Can you post a side few of the black switch showing the hole? I'd like to see that hole in profile. See picture below.
    I see there is already a small 1/8" which I never noticed before. Without having the lock in hand, it appears that simply using that as a pilot hole, drilling it out 5/16" may not quite work. It looks like you need to offset the 5/16" hole from that hole, suggesting a drill press might be best. I don't typically charge in public, but I have taken my cord on trips (even with an extension cord). I am more inclined now that I can lock it. Also, I am installing chargers for commercial clients. The ones we are using come with (2) Level 2 cords and (2) Level 1 outlets. I am told by other electricians that workers often doe-see-doe the connections in the parking lots, disconnecting others. For level 1 charging this would prevent that as well as thefts, which is the main concern.
  5. Violet Rose
    Violet Rose Junior Member
    Norman.Oklahoma
    2019 Prius Prime
  6. bisco
    51,840
  7. Violet Rose
    Norman.Oklahoma
    2019 Prius Prime
    ALL that matters is you have a Lock that will fit the hole on the EV charging cable. If it didn't fit then drill the hole bigger. But not a Cheap small lock that is easy to cut off. That is why i gave you the basic why to change the hole size.
    Rob43 and bisco like this.
  8. shebobg
    shebobg Junior Member
    46
    Woolwich Township, NJ
    Where do you get a Fast Charge Adapter? I just came back from a long road trip on the Turnpike and notices that in order for us to charge our cars we need a Fast Charge Adapter. Never heard of it and was take by surprise. Is this something you can buy from Toyota or aftermarket? Thanks for any help.
  9. Salamander_King
    Salamander_King Senior Member
    11,016
    8,947
    New England
    If by "Fast charge adapter", you mean to charge your PRIME at Tesla's supercharger station, then you are out of luck. AFAIK, Tesla will not let non-Tesla cars to be charged. For non-tesla BEV there is DC-Fast charge station, but it uses CHAdeMO connector and this is also not compatible with PRIME in the US. The Japanse version of PRIME, Prius PHV is equipped with CHAdeMO plug-in capability. The only option your PRIME has for faster charging is using public L2 EVSE at 240V. It still takes ~2 hrs to charge full 25 miles EV range. I think most L2 charge station is equipped with J1772 plug compatible with PRIME, so you don't need an adaptor.
  10. shebobg
    46
    It wasn't a Tesla station but it was a CHAdeMO and a fellow was charging his electric car there and said for me to use it I would need an extension, not necessarily a Fast Charge Adapter. The extension is supposed to let you use the charging station but it would still take a couple of hours to charge...not "fast charge". Never heard of it. If all turnpikes have only these and Tesla's, then we can't charge our cars. My husband and I did notice that the handicapped aisle did have the charger we need....but we're, thankfully, not handicapped.
  11. Salamander_King
    11,016
    8,947
    New England
    I've never used public charger on my PRIME, for there is no public charge station within 200 miles from our home. Plus sitting for a couple of hours for mere 25 miles of EV range is not very productive use of my time. Plus, the price for public charge station is usually much higher than what I would pay for gas for the same distance I can drive.
    That being said, if you really want to charge your PRIME, you can find some charge station you can use without any adapters. You have to find a charge station equipped with J1772 plug. I maybe wrong, but AFAIK, you can't used DC fast (CHAdeMO plug) on PRIME. Try this site to find compatible charge stations you are looking for. Just pick J1772 as you choice.
    PlugShare - Find Electric Vehicle Charging Locations Near You
    #31 Salamander_King, Jun 24, 2019
    Prius from Dad likes this.
