Malfunctioning NAV head
Discussion in 'Gen 3 Prius Audio and Electronics' started by rottie*lover, Jun 14, 2013.
  1. rottie*lover
    rottie*lover Junior Member
    Reading, PA
    Our 2010's NAV head has recently begun throwing fits. Sometimes it's hard to get it into route planning mode via the touch panel. But, what's more prevalent is when the "hard" buttons are pressed the unit does other things; most often, for example, is that the "map" or other hard button is pressed and instead of the screen going where it's supposed to it'll switch radio stations.
    Nothing foreign has been spilled, stuffed, or crammed into it. The car is garaged.
    Questions: Any way to do a hard reset? Is this a warranty issue? Anyone else have this problem?
    Or, do I just cave and call the dealer?
    Thanks in advance. If this has come up before, sorry, but I couldn't find anything in a forum search.
    -Matt
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    The Nav unit is covered by the basic 3 year / 36,000 mile warranty.
    Someone else was having issues with their Nav unit and disconnected the negative lead to the 12V battery to reboot everything and this resolved their Nav issues. Another person added a fuse that could be pulled to reboot the Nav without disconnecting the battery.
    Try to do a search and see if you can locate the thread.
  3. rottie*lover
    Reading, PA
    Thanks jd, I'll do just that!
  4. peterjmc
    917
    188
    Clarksburg, MD
    When I had my 2010, my Nav buttons no longer worked in their labeled functions. I was lucky to be able to get it replaced under warranty. I got an upgraded Nav map in the process :)
  5. Aeroplay
    Aeroplay Junior Member
    Cornelia, Ga
    This is exactly what is going on with mine. It started a couple of months ago; once in a while it would do this however, now it's anytime you press a button it changes channels or goes to another function.
    Did you try pulling the negative cable? Is it resolved?
    Herb
  6. rottie*lover
    Reading, PA
    Hi Herb!
    Before I got a chance to deal with this, my wife traded in her Prius for a Subaru Outback.
    We loved the MPG this car got. There were other things that she/we didn't like: the nose clearance being so low that it would scrape on the road depending on the camber/angle, etc.; how sometimes in the winter it wouldn't be able to get up our driveway (600' on a hill). And, she never felt safe having to brake in the rain across certain things (railroad tracks, manhole covers), because it felt as though her brakes weren't "grabbing" under those conditions. This may or may not have been a problem, but I know this has been posted before from other folks on this forum as I did some research about it at the time.
    I suggest you search this forum for more info on the NAV. Personally, I know if my computer is acting wonky (and it's been turned on for awhile) the best remedy is a reboot. I don't see how this would harm things if your were to do the same. But then again, better safe than sorry.
    For those of you tempted to flame back because of paragraph #2, don't bother- the Prius is a nice car, just didn't fit what was needed. I was tempted to keep it for myself, but still have my all wheel drive Passat because I need to get up our driveway too!
    Good luck with your quest; let me know how you make out!
    -Matt
