Man Based Global Warming....
Discussion in 'Environmental Discussion' started by dbermanmd, Dec 22, 2008.
Thread Status:
Not open for further replies.
  1. Fibb222
    Fibb222 New Member
    1,499
    99
  2. wxman
    wxman Active Member
    636
    231
    Tennessee
    The following is admittedly somewhat oversimplified, but generally serves to convey how large-scale differential heating drives weather systems...
    As is commonly known, air expands when heated and contracts when cooled. This actually happens on a very large scale in the atmosphere at the equator (tropics) where heating causes relative expansion in the vertical while the cold polar regions experience relative contraction in the vertical.
    This relative expansion/contraction can be measured and is known in meteorology as “height fields” – typically 500 mb heights – which are determined by the altitude (“height”) at which the 500 mb pressure is encountered (surface pressure at sea level is typically slightly more than 1000 mb, so 500 mb would be about half the surface pressure). This can be as much as 6000 meters in the tropics to as low as 4000 meters in the polar regions.
    These south-north “height falls” are roughly analogous to surface pressure gradients which in turn are analogous to topographic map contours. Differences in heights result in the equivalent of a pressure gradient which causes air in the upper levels to rush from high pressure to low pressure. Forces resulting from the earth rotating on its axis (Coriolis Effect) cause the wind field to be deflected to nearly parallel to the height contours (ageostrophic wind). This is why you usually see the “jet stream” flowing from west to east and not south to north (other than extreme amplifications).
    The strength of the ageostrophic wind field is determined by the gradient of the height falls. As I mentioned previously, strong ageostropic wind fields induce dynamics favorable for organized severe weather events (usually also associated with amplification in the flow). This is why it would be my expectation that warming the polar regions relatively more than the tropics would generally result in gentler height falls which in turn would result in weaker ageostrophic wind fields and thus fewer/weaker severe weather events in the mid-latitudes.
    I do agree that the potential exists for stronger tropical cyclones in a theoretically warmed atmosphere since they favor weak ageostrophic wind fields (relatively strong upper levels winds (ageostrophic winds) typically disrupt the vertical structure of hurricanes/tropical storms).
  3. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    I hate it when really good and informative posts seem to end the thread rather than sustain it. Thx wxman
  4. patsparks
    10,664
    567
    Adelaide South Australia
    Funny thing is, I agree that climate change affected by the activities of man is real and we need to act, I agreed with this before I got my Prius, I didn't join PC until I got my Prius, I never heard of Al Gore before I joined PC.
    Should I pray to Al Gore? I don't think so.
  5. harmonsmith
    harmonsmith New Member
    We humans are destroying our world for our future generation
  6. Fibb222
    Fibb222 New Member
    1,499
    99
    But we could have saved it... Thanks for nothing George. Your eight years would have made a difference.
  7. Alric
    Alric New Member
    1,526
    87
    You've come in contact with Al Gore derangement syndrome. Part of the political discourse in America is that a group of conservative pundits work relentlessly to vilify the positions of the left and prevent rational discourse. Formally known as the Republican War on Science.
    They have worked tirelessly to call people with an education "elitists" and created most of the idiotic aphorisms of the past eight years": "if you don't support the war you don't support troops!" or "small government not big government!" or "life begins at conception!".
    One of their most important tools is the "balanced view" approach where any idea should be counterbalanced by the opposite view during exposition, no matter how ridiculous it is. We have a whole news network (owned by an Australian ironicaly enough!) devoted to this concept. Fair and balanced they say...
    In this view things like cosmology, evolution and global warming were all suspect as coming from a left political agenda and not the result of science and research.
  8. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Well, science is a religion didn't you know? That's what the conservatives have been telling us for at least the past decade. The same nonsense is repeated frequently in this thread by most of the denialists.
  9. malorn
    malorn Senior Member
    4,281
    59
    "Somewhere in Flyover Country"
  10. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    What's really cute is when a person like me, who was raised as a Conservative in the very real and literal sense, with tons of post secondary education and military service, is also vilified by the current crop of neo conservative fascists
    I guess the closest match I have right now is the Libertarian movement, but only in a few select topics
    What I believe in: a fiscally responsible government that isn't bloated, personal responsibility, an absolute NO to these "bailouts" that have committed us to Indentured Servitude, and the simple desire to lead my life the way I chose to do so.
  11. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Jayman, there are a LOT of people like that. If the GOP doesn't pull its head oot its arse soon, we may be blessed with a proper conservative party to compete with it and the democrats. Inshallah, it will be so. (sorry, couldn't resist).
  12. patsparks
    10,664
    567
    Well as my concern for the environment goes way back to when I was in high school, that is pre 1978, how did I come in contact with Al Gore derangement syndrome?
    The real trouble seems to be the American-centric opinions of some people who still seem to be stuck in the greed is good and capitalism will solve the problems of the world, era.
    Strangely, contrary to your text above it is the most educated who seem to populate the "Al Gore" camp while the truck drivin' tobacco chewin' Marlboro smokin' red-necks seem to almost unanimously support the view that there must be a dollar in this environment crap cos it can't be true. Of course the multi billion dollar petrochemical industry and other dirty energy industries have no vested interest in supporting contrary science and no scientist would sell out to a cashed up petrochemical company, ever. It is no wonder the governments of the world are skinned, they have been paying for crooked science now for years and using the research of these crooked researchers to manipulate the population but, and here is the big but, the government denied the existence of climate change until the pressure became unbearable, nice poker play there western governments of the world, well done!!
  13. Alric
    Alric New Member
    1,526
    87
    Pat! I think you read me backwards mate.
    You came in contact (but did not contract) Al Gore derangement syndrome in this very forum.. :)
    Cheers!
  14. JSH
    JSH Senior Member
    2,605
    140
    PDX
    Alric is making fun of those of us that believe that though Al Gore's "An Inconvenient Truth" exposed a lot of people to the topic of climate change it will in the end backfire due to the wildly exaggerated claims made in the movie.
    It is also an insult thrown at those that get their information of the topic of climate change from major media sources such as magazines, newspapers, TV, and documentaries. Alric maintains that Al Gore is irrelevant because he is not a climate scientist and we should only concern ourselves with what is published in scientific journals. Alric is thumbing his nose at the uneducated masses that are intellectually inferior to him.
    What Alric is missing is that the vast majority of the population has never read a scientific journal and instead relies on the major media for news. The debate over climate change will be won or lost based on public opinion. That makes Al Gore and spokespeople like him more relevant to the debate than all the journal articles in the world.
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    Unfortunately, I feel you are overly optimistic. I briefly felt that way here about the Conservatives, now look at how they formed a de facto coalition with Ignatieff's Liberals, and sent us off the Fiscal cliff
    It was almost worth it though, to watch Jack Layton carry on like a little boy in the schoolyard. It was Layton's only serious shot at getting reins on government, and Ignatieff back-stabbed him.
    Really, *really* back-stabbed him
  16. jayman
    13,439
    641
    Winnipeg Manitoba
    Well, that is the problem right there. Our education system has become so dumbed down - which is directly reflected in our mass media - that the majority of folks cannot even understand basic scientific principles.
    I tend to rant about things like our "edumacashun" system, but it really is broken. We're cranking out high school graduates who can barely read at all. We should be ashamed of ourselves
  17. JSH
    JSH Senior Member
    2,605
    140
    PDX
    I won't disagree with that. The US population in general has a very limited understanding of math and science and very little interest in either. I assume you have a similar apathy in Canada.
    However, what should be and our current reality are two very different things.
  18. Fibb222
    Fibb222 New Member
    1,499
    99
    Did Al Gore really get it so wrong by being too alarmist?? - if anything it's the contrary.
    He hardly even spoke about the massive geo-political upheaval that is bound to happen when the 2 billion people in the sub-tropics try to survive on a small fraction of the water (and therefore food) they have now.
    We are on course for catastrophic human suffering and denialists are fixated on a bogus sea level rise criticism????
  19. JSH
    JSH Senior Member
    2,605
    140
    PDX
    • In 'An Inconvenient Truth", Al Gore predicts a sea level rise of 20 feet (610 cm) unless we act now. He shows deeply emotional simulations of major population centers flooded due to global warming.
    • In its 4th assessment, the IPCC predicts a sea level rise of between 18cm to 59 cm over the next century.
    That is an order of magnitude difference and yes it is alarmist.
    Al Gore's wild exaggerations will hurt the credibility of the global warming community, especially when he refuses to admit he exaggerated. Instead he has said: "Of course, there will always be questions around the edges of the science, and we have to rely upon the scientific community to continue to ask and to challenge and to answer those questions..... "but we do agree on the fundamentals.â€
  20. Fibb222
    Fibb222 New Member
    1,499
    99
    The IPCC report's predictions are extremely conservative - major indicators of global warming are way ahead of their predicted schedule. And as we already pointed out, there are scientific papers saying that 7 meters is not impossible.
Thread Status:
