Mandatory Update Entune
Discussion in 'Prime Audio, Electronics, and Infotainment' started by schja01, Mar 20, 2019.
  1. schja01
    schja01 Senior Member
    1,865
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    I got in my Prime (Advanced) today and was greeted with a PopUp on the Infotainment Screen that a "Mandatory Update" was available. I downloaded and installed it but blew by option to display what was changed. Sorry. The update went without incident. I don't notice any changes but haven't looked extensively either. The whole process took about two minutes to download, install and reboot.
    J
    jerrymildred likes this.
  2. ronus20
    ronus20 Junior Member
    San Jacinto, CA
    pghyndman and jerrymildred like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    I'll try to remember to document the changes when I do mine. I delayed mine this morning because I didn't know how long it would take. Now that I know it won't take long, I'll probably do it tonight or in the morning. Not that I ever use Entune. Without the neat charging stuff you Advanced owners get, it has absolutely nothing that's useful to me.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,976
    New England
    I have never used Entune in the car, and do not have the app installed on my phone. I don't have Advanced trim so absolutely no use for the app. I wonder what happens if I never do the Mandatory Update?
  5. jerrymildred
    11,517
    14,164
    Tampa, FL
    I imagine it will nag you till you give in. :)
  6. schja01
    1,865
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    I did some searching on the Interweb and only found a mention to MovieTickets going away May 15, 2019. Nothing about today’s update specifically.
    There was a button during the update process to display details but I skipped it as I was driving the car at the time.
    The update was minimally distractive. I think 3 buttons.
  7. Salamander_King
    11,024
    8,976
    New England
    I have never seen those update screen on my car's 11.6" screen, although I have the screen off most of the time. When and where does it show up?
    EDIT: I saw @ronus20 photo above. So it does show up on the 11.6" screen. Humm, let me check this out in my car. Will be right back
    #7 Salamander_King, Mar 20, 2019
  8. jerrymildred
    11,517
    14,164
    Tampa, FL
    I did the update. Didn't see anything that hasn't already been shown here. I then looked at the charging station app when I got home. After about 30 seconds of that, the screen rebooted. Entune sure sucks. I hope it doesn't start rebooting when I'm not using Entune. It's the first time that's happened to me and it the first time I used Entune.
  9. Salamander_King
    11,024
    8,976
    New England
    OK, I checked it out in my car. I go Menu and touch App Suite. I got this screen info. Since I never installed Entune on my smartphone there is no Mandatory Update for me. I hit the "Do Not Tell Me Again" and turned off the screen. I will probably never see that screen info again. THE END
  10. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Same scoop with me, FWIW: No signs of concerns, loaded pretty quickly, not obvious what changed.
    “Mostly harmless”
  11. Praeluceo
    Praeluceo Junior Member
    I got it also, but the description was certainly not a changelog. IMAG1392.jpeg
  12. schja01
    1,865
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    The iOS app just got updated as well.
    The change log is next to useless.
    J
  13. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
  14. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    I see the announcement on the screen, but every time I tell it to 'update now' it fails the download. I'm glad it's not anything really important...
