Mando Struts for Gen 3 Prius
Discussion in 'Gen 3 Prius Technical Discussion' started by Michael Wood, Nov 12, 2022.
  1. Michael Wood
    Michael Wood Active Member
    181
    118
    Boston, MA
    2020 Prius Prime
    There aren't many reviews on Mando aftermarket struts. Mando is new to the aftermarket business. They are the Korean OEM strut manufacturer for Hyundai, Kia, and more recently Volkswagen.
    I decided to give Mando a try on my 2015 Prius. I bought the struts (complete assemblies - spring, strut, mount, bellows) at Rockauto for $129 each. About 1/3 less expensive than KYB.
    They were packaged up nice. Both fit and finish were perfect. I weighed the complete assemblies of both the new Mandos and original KYB's with 163,000 miles on them. The Mandos were just slightly heavier, and have beefier springs - pics attached.
    I also replace the sway bar links with new Mevotech's with grease fitting. They were twice as heavy as the OEM links, much better built.
    The ride is fantastic - feels like a new car again. We'll see how they hold up. So far I'm very happy with both Mando and Mevotech.
    #1 Michael Wood, Nov 12, 2022
    Ryan Will likes this.
  2. Ryan Will
    Ryan Will Member
    68
    43
    Southern California
    Hello!
    I'm just curious if there's any updates on how the Mando struts have been treating you. I've been looking into them as well and just curious how they've been longer term.
    Thanks!
  3. Helveticus
    Helveticus Junior Member
    Los Angeles
    Just replaced my struts with KYB struts plus ($480 Amazon). Was hoping all the negative reviews was due to improper installation and/or other suspension components gone bad. Nope, these KYB struts plus are defective. I've replaced control arms, ball joints, stabilizer links, bushings and tie rod ends. And I double checked torque settings but the struts still makes a "springy" noise. Plus, the ride feels marginally better than the old struts.
    Never heard of Mando but glad they worked out for you. Think I'll go with Monroes...
  4. Michael Wood
    181
    118
    Boston, MA
    2020 Prius Prime
    I'm really happy with the Mando struts. No complaints at all. I'd definitely buy them again.
  5. Sangyeoul Bae
    Sangyeoul Bae New Member
    Ca
    Where did you get the Mando struts?
  6. Michael Wood
    181
    118
    Boston, MA
    2020 Prius Prime
    Rockauto.com
  7. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Does this noise occur when you turn the steering wheel? If so it's your torrington bearings making noise You didn't open them and regrease them.
    KYB sold on Amazon is probably Chinese imitation. Never buy anything on Amazon
    Only thing worse than Chinese junk is Monroe
  8. douglasjre
    2,250
    751
    Null, NL
    Do you have any specifications on these shocks? Like are they digressive how are they valved Do they have a nitrogen charge etc? Do you know what the spring rates are? I have a lot of questions on the aftermarket stuff. Any spec sheet?
  9. Michael Wood
    181
    118
    Boston, MA
    2020 Prius Prime
    I agree. Avoid Monroe at all costs - even their premium stuff is junk. I took a chance on their OE Spectrum rear shocks - how tough can it be to make a quality shock absorber for a company with 100 years experience. I regretted my decision.
    douglasjre likes this.
  10. dcwenger
    dcwenger Junior Member
    64
    Canyon Lake, CA
    Do you have the part numbers for these Mando struts? I am looking on RockAuto and oddly, the only thing I can find it the RF (part # MSS050496). They don't seem to show the LF for the Gen III (2013).
  11. dcwenger
    64
    Canyon Lake, CA
    Nevermind my previous question. Now I see why it is not listed. On the Mando website it says "discontinued", but the replacement part # shows "proposed".
  12. douglasjre
    2,250
    751
    Null, NL
    Imposters
  13. GoGreenCouriers
    GoGreenCouriers Junior Member
    Dallas, TX
    ***Warning for Prius Plus/Prius 5 owners***
    I just thought I would add a comment here about the Mando complete struts. I installed these on my 2015 Prius Plus over the weekend. Once I lowered the car the frontend sat very high with the complete struts installed. There was about a 6 inch gap from the fender to the tire. After fully inspecting the struts I realized the springs on the Prius Plus or higher trim models are shorter. The solution was to remove the Mandos and rebuild them with my old springs. Once this was completed the car sat normal with the old springs. Aftrer driving about 200 miles on the HL Mando shocks I would highly recommend these as OEM replacements. It drives like a new car. Based on the recommendation in this thread I also replaced the original sway bar link with the Mevotech, which is a major upgrade from the original Toyota part. The steering is very tight now with little to no slack in the wheel on turns. Overall I would recomend the Mando Struts with the Mevotech upgrade for a "good as new" feel on the Prius...maybe even better than new with that Mevotech link upgrade.
  14. douglasjre
    2,250
    751
    Null, NL
    More Chinese junk
  15. bluecrazymonkey
    bluecrazymonkey New Member
    26
    Earth
    How are they so far? You still using them? how many miles you got them on now?
