Manual Timer Charging
Discussion in 'Prime Plug-in Charging' started by sumting77, Feb 23, 2017.
  1. sumting77
    sumting77 Junior Member
    22
    So Cal
    2015 Prius Plug-in
    I apologize if this has been discussed before but I couldn't find anything.
    I recently purchased a Prime Plus and this does not have the timing preferences for charging.
    I am wondering if anyone has considered using a heavy duty outlet with a timer? There are quite a few surge protectors that have this functionality. I assume that you could set it to "turn on" power to anything plugged in during non-peak hours (12am-6am for example).
    Edit: Thanks all!! Turns out the plus model DOES support charging preferences! Sorry for the confusion, I will work on my google skills :(
    #1 sumting77, Feb 23, 2017
  2. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    That is a pretty good idea.
  3. sumting77
    22
    So Cal
    2015 Prius Plug-in
    I guess the biggest concern would be finding the right one with the risks associated...
    Per the manual they state the following:
    ●Do not connect the charging cable to a multi-outlet adapter, multi-plugs, or conversion plug.
    ●Connecting the charging cable to an extension cord is strictly prohibited. The extension cord may overheat and does not contain a Ground-Fault Circuit-Interrupter (GFCI).
    ●Do not connect to a power strip.
    MikeDee and yoyoman like this.
  4. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
    you can schedule your charging to start at certain time or end by certain time based on each day (weekday or weekend), so you don't really need a separate timer, which would potentially cause a problem since it might not be able to handle the load during charging
  5. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    The Plus version doesn't have all the Charge-scheduling provisions? I didn't realize that...
    Anyway, I gather that the 120V charge cable provided has a nominal current of 15A (more like 12A in practice, but plan for >15A). If you have to use any sort of external timing or extension-chord equipment, as long as it's rated for, say, 18-20A, it's probably doable.
  6. mr88cet
    2,313
    1,335
    Austin, TX
    It sounds like the OP believes that the Plus version doesn't have the charge-scheduling features of the Premium or Advanced. That struck me as surprising, but not impossible, I suppose...
    iPhone ? Pro
  7. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    I have a PLUS and you can schedule it to charge now or to be charged at what ever time on what every day or days you wish. With a 120V outlet you can charge at 12A or 8A.
  8. Optimus PRIME
    180
    141
    SF Bay Area
  9. Optimus PRIME
    180
    141
    SF Bay Area
    hey take a look at video #18 ... it might help you
    Toyota Prius PRIME 2017 (New Model) - YouTube
  10. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    For longest battery life it is best to have it set for a departure time since having the battery at full charge for a long time is not optimum. It is my belief that a 120V charge using 8A is best for battery life and a quick charge using 240V would be the worst for battery longetivity. But I am willing to be educated if someone knows more about extending battery life.
