manufacture date
Discussion in 'Prius c Main Forum' started by novaz, Jun 11, 2019.
  1. novaz
    novaz Junior Member
    47
    arizona
    2015 Prius c
    I have a 2015 registered prius c3 but have noticed several changes from other so called gen 3 s particularly all the videos I watch concerning transmission oil change show the fill and drain plugs on one side mine are on different sides of the transmission fill on one side drain on the opposite side is this normal how can I tell when car was actually manufactured.
    Thanks
    52,679
    are they prius c video's?
  3. novaz
    novaz Junior Member
    47
    arizona
    2015 Prius c
    some are some not but the two plugs I found are for sure covered in trans fluid I also found the maintenance reset was different
    52,679
    not sure about maintenance reset, but i don't think they changed the transmission at all. it may be different from the lift back though.
  5. novaz
    novaz Junior Member
    47
    arizona
    2015 Prius c
    ok thanks also no big plastic cover which is ok as it looks to be a pain to remove
  6. bisco
    52,679
    underneath? not sure if the c has that or not
  7. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    The vehicle manufacture data is on a placard mounted on the driver door jamb. Looks like this. If you run your VIN through the Toyota website, it will tell you exactly what car you have.
