Many codes, black in battery fan wires, red triangle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SanGregprius, Jul 5, 2022.
  1. SanGregprius
    SanGregprius Junior Member
    42
    17
    san gregorio ca
    I've got a 07 with a 2 year old Green tec auto battery and a couple of days ago got the red triangle, engine and vc.
    I also got a P3190 with poor engine power so I cleaned the throttle body with %97 alcohol.
    And I also got a P3000 replace battery control system.
    Car driving fine.
    The bludriver OBD app showed the P0A80 code first then the others after a few clearing of codes.
    I ordered another OBDii and before I realized it was for android I did get it to work for a few minutes and the readings looked fine. I couldn't get the battery fan to work with the raising the batt temperature trick. The fan had a corroded connector. I bypassed one of the wires 2 years ago when I got a new battery.
    After trying to splice in a new connector I'm getting a fuel run-out code P3193 and
    P300 (battery control system) and the car won't shift into drive.
    A quick search shows that black copper isn't that bad, but just looking for some help here.
    There was a trouble shooting guide for the fan but I can't seem to find it again. I was a bit confused by the guide but know some of the tests were okay.
    I'd also love a wiring guide to maybe hot wire the fan to see if it is working if anyone had access.
    #1 SanGregprius, Jul 5, 2022
  2. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    This is for the fan in the back for the HV battery
  3. Tombukt2
    13,875
    2,521
    Durham NC
    So it looks like you need two plugs I should have them
  4. SanGregprius
    42
    17
    san gregorio ca
    I've replaced the plug. The car started back up and is only giving me the P0A80 code again. ugh two year old Green Tec auto battery going bad already...no wonder it is only a 12month warranty.
    SFO likes this.
  5. Tombukt2
    13,875
    2,521
    Durham NC
    It happens I have a green tech battery here that went bad and about two three something like that it may be salvageable it might be just to be balanced or see what cells are croaking and change them out I don't know what to tell you about that
  6. PriusCamper
    PriusCamper Senior Member
    13,472
    5,439
    Pacific Northwest, USA
    P3000 is part of the P0A80 error code. It means you got a bad battery module, aka: too great a voltage difference between the bank of 14 blocks. Install Dr. Prius app and share some screenshots so we can help diagnose which block is bad in your battery pack.
  7. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    The OP might have better luck researching the actual code which is P0A80.
    The second character is always numeric and can only be 0, 1, 2, or 3.
  8. PriusCamper
    13,472
    5,439
    Lol, that was a typo I fixed less than 20 seconds after I posted... You're wasting your time!
  9. dolj
    dolj Senior Member
    8,652
    4,404
    I don't see any edit, but ok. It still is good information for others to know what the correct code is.
  10. SanGregprius
    42
    17
    san gregorio ca
    thanks once I get the correct dongle I’ll post. When the android obii and dr Prius worked for a few minutes everything looked fine.
    I took apart the og battery and replaced 2 Modules only to get red triangle again in a few weeks so I’m skeptical.
  11. PriusCamper
    13,472
    5,439
    This one works good and less than $20: https://www.ebay.com/itm/265484403768
    As you drive your battery pack down the road there's certain moments of charge and discharge when the amps are just right that the voltage difference between blocks will get too high and it'll log the P3000 code. So it's an intermittent problem at first and you can go a long time just clearing the code while you drive as long as the pack doesn't start running too hot. And if you can afford it, buy one of these: https://projectlithium.com/?ref=9qLPw and it'll feel like you own a much newer Prius than you currently have.
  12. SanGregprius
    42
    17
    san gregorio ca
    ironically that is the obd I bought but I am apple user.
    My Prius has been great. About 200k and the only main repairs are the dash, wheel hub, inverter fan, and hv battery but a lot of little things are falling apart. Starting to feel like whack a mole.
    #12 SanGregprius, Jul 6, 2022
  13. SanGregprius
    42
    17
    san gregorio ca
    Doing the math I think I'm going to replace the battery. Green bean does a full HV with lifetime warranty for about $1500.
    Seeing cost of new and used cars right now.
    Wondering if I need to wait for this Dr Prius app OBD to confirm a cell or if the BlueDriver app giving me the same P0A80 code after resetting multiple times is telling enough.
    THanks for any input.
  14. PriusCamper
    13,472
    5,439
    Replacing the pack will save you lots of hours of diagnostics, module replacement and reconditioning. Of course that's assuming the $1500 is less valuable than the hours you spend rebuilding your pack.
    SanGregprius likes this.
  15. SanGregprius
    42
    17
    san gregorio ca
    So it's a bit of a guarantee that the HV battery needs work and is on the way out? I'm two days in so far and need the car back asap. It's 3 days till the first available green battery app...
  16. PriusCamper
    13,472
    5,439
    Usually the first module that needs to be replaced is the easiest amount of effort and lasts the longest. Future modules will die more often once that part starts. But that also has to do with how good your replacement module is, as well as if your pack needs reconditioning or not.
  17. SanGregprius
    42
    17
    san gregorio ca
    I got a new code today P3016 on the blue driver OBD. "battery block 6 becomes weak. I'm not finding other post that say this is a specific modual code as I don't trust the Bluedrive app.
    I take it this is a more precise code than the P0A80 code? why would they have two codes for the same thing?
    I'm twiddling my fingers waiting for the Dr Prius OBD to tell if it is just the HV battery or something else.
  18. PriusCamper
    13,472
    5,439
    P0A80 code is marketing department selling new battery packs no matter how minor the problem... P3016 is kinda like a subcode for people who'd rather repair a pack than buy a new one. You're gonna need some high quality replacement modules. This is who I get them from. Top quality every time: https://2ndlifebattery.com/product-category/toyota/
  19. dolj
    dolj Senior Member
    8,652
    4,404
    That is one way to look at it if you ascribe to a particular train of thought, but what P0A80 (P-zero-a-eight-zero) really means is there is a problem detected in the HV battery, more detail to follow when it becomes available.
    Toyota chooses to deal with any problem with the HV battery that might occur is replacing the entire pack. Given the difficulties of doing reliable and timely module replacements, this is entirely reasonable. Toyota's focus will be to do a reliable repair that inconveniences the customer in the least possible way.
    The fact that DIYers might choose to bear the brunt of inconvenience in exchange for a less expensive route is also reasonable but it doesn't make it a better approach.
  20. PriusCamper
    13,472
    5,439
    Lol, that's the most ridiculous thing I've ever read on PriusChat... You really think warranty repair specialists are going to keep your car on the road for an affordable price to avoid you any inconvenience? What planet do you live on?
    In the US and Europe we get people on here often who have a bad battery pack that shows up as a bad inverter error code and before checking to make sure it's not the battery they charge $5K for an inverter and then shrug their shoulders because it turned out the be the battery pack and expect you to double down and pay even more. That's criminal negligence as far as I'm concerned!
    The P0A80 error code literally says: "Replace Hybrid Battery Pack" even when the problem is minor and takes less than 5 minutes to fix. But if you take that less than 5-minute to fix problem to the Stealership they will say it costs $3K to $4K to fix. If we had legitimate consumer protection laws it'd be a legit crime to take advantage of your obvious gullibility.
    No need to reply to me either, I'm putting you on "ignore" so I don't start saying inappropriate stuff to you.
    #20 PriusCamper, Jul 8, 2022
