Map DVD has stopped working
Discussion in 'Gen 3 Prius Audio and Electronics' started by DallasDad1000, Aug 12, 2015.
  1. DallasDad1000
    DallasDad1000 Junior Member
    17
    Dallas
    It says it does not see my DVD. If you eject it and put it back in, it will rarely come on a few seconds then back to not seeing the DVD. Anyone have an idea on how to fix it? Any seggustions?
    Se
  2. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    Any scratches or dirt on the disk?
    It's possible there's dirt on the lens used to read the disk too. Sometimes I've had luck at fixing optical drives by blowing compressed air into the slot. Of course, that just blows the dust around, so it might make it better or it might make it worse. So I'd recommend replacing the disk (or at least borrowing someone else's) first to make sure. If it's not the disk and your only option is to replace the nav system, blowing some dust around is a lot cheaper and easier, even if there's some risk of making something worse.
  3. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Optical disks read from the center of the disk first, so make sure the disk surface at the center portion is clean and scratch free.
  4. DallasDad1000
    17
    Dallas
    I guess what I do not understand is that I never take the navigation disc out, so why would it be scratched?
    iPhone ?
  5. macman408
    1,179
    368
    You already said you took it out to try and fix it! ;)
    Unlikely, but it would be possible for it to get scratched while going over a bad bump, jostling the pieces inside the optical drive or the disk itself so that something scraped. Random dust or some other type of failure is more likely.
  6. DallasDad1000
    17
    Dallas
    Took it out only after it stopped working.... Just upset. Too bad.
    iPhone ?
