Map Light Housing Issue
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ben J, Jul 13, 2020.
  1. Ben J
    Ben J New Member
    Minneapolis
    Hello, today I was replacing my map lights with LED ones. While I was able to get the passenger side swapped out easily, I struggled with the drivers side. I ended up getting the old bulb out but accidentally pushed the black piece that the light plugs into up into the housing. I am wondering what the easiest way to fix this would be, to order a new black piece or to try and detatch the panel and get it from the other side. I will include a picture the black piece I am talking about. Thank you.
  2. SB6
    SB6 Member
    324
    71
    I've never messed with interior lights yet, so I really don't know what in talking about, but are you not able to fish the piece back out?
  3. amarino
    amarino Active Member
    143
    105
    99
    Its really easy to pull down the whole housing, at least in my 2015 Two.
    First snap off the front curved piece right above the rear view mirror. Here is mine removed while I was running some dashcam wires.
    Then pull down firmly but gently until the whole housing snaps out and unplug the cable so its free. You can also see the rear of the bulb holders in the below pic:
    The black bulb holders in the middle of the green PCB.
    SB6 likes this.
  4. Ben J
    Ben J New Member
    Minneapolis
    Thank you for all your help I was able to remove all the housing very easily and re install the light!
