Map light replacement Prius Three with Tech Package
Discussion in 'Gen 4 Prius Accessories and Modifications' started by NguyenCB7, Mar 3, 2016.
  1. NguyenCB7
    NguyenCB7 Member
    71
    67
    Fullerton,ca
    hello everyone! I read the post about the Prius four but mine has the tech package with sunroof or the map light cover is different. Does anyone know how to remove it? Thank you for your time
  2. krmcg
    2,592
    2,393
    Whittier, CA
    Upgraded light bulbs would be a good thing...
  3. NguyenCB7
    NguyenCB7 Member
    71
    67
    Fullerton,ca
    Yup, Bought some bright LEDs but now I need to open the Map cover without breaking anything
  4. glennonrp
    glennonrp Active Member
    178
    199
    Fontana, CA
    Four Touring
    It's probably the same. I suggest a plastic pry tool. Go slowly. The plastic clips will pop out with some effort but be careful.
    iPhone ?
  5. NguyenCB7
    NguyenCB7 Member
    71
    67
    Fullerton,ca
    Ok, got my friend at Toyota to get me the diagram but per his request I can not share it. I am able though, to show you how to do it if you have questions but pretty similar like Glen said. Here's some pictures. PM me if you have questions.
  6. NguyenCB7
    NguyenCB7 Member
    71
    67
    Fullerton,ca
    Just becarful.....
  7. NguyenCB7
    NguyenCB7 Member
    71
    67
    Fullerton,ca
    More
    glennonrp and Oversplode like this.
  8. Backwoodzcustomz15
    53
    53
    Lancaster, pa
    Three Touring
  9. d4vr0s
    d4vr0s Junior Member
    Knoxville
    I've replaced the map lights in my 2017 4 with the AT package, it was a pain but worth it.
    I got between the plastic and headliner on the windshield side and started pulling
    The cover popped off with a crack sound and thought for sure I broke something, but upon inspection it was undamaged.
    Then I carefully worked off the clear covers over the lights, they come off relatively easy once you get one corner started.
    You'll want to pull the lights straight out, don't twist because the socket could disconnect and it's on the top side of the module.
    Here's some pictures from another thread of someone who pulled out the entire module.
    How to Change Front Map Lights. | PriusChat
  10. Backwoodzcustomz15
    53
    53
    Lancaster, pa
    Three Touring
    Is the AT package different from mine? Cause mine couldn't get any easier.
  11. d4vr0s
    Knoxville
    Yes, mine has moon roof controls and there isn't a sunglasses holder.
    The map light cover edges are behind another cover that goes over moon roof controls.
    Edit:
    I tried pulling the whole thing out but got worried about damaging the headliner.
  12. Backwoodzcustomz15
    53
    53
    Lancaster, pa
    Three Touring
    O ok, we wanted a sunroof but none are had any. In fact I have yet to see 1 with a sunroof in person.
  13. NguyenCB7
    NguyenCB7 Member
    71
    67
    Fullerton,ca
    You can remove the lens that cover the lights. It a little hard to get into but it is possible to change the lights without remove the whole thing.
  14. Backwoodzcustomz15
    53
    53
    Lancaster, pa
    Three Touring
    Please do a video, cause the bulbs come in from the back. So I'm gonna say it's impossible to do it any other way.
  15. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    I changed mine by just removing the lens.
    We do not have the moon roof option in the UK. Just put a loop of sticky take around the bulb and it makes pulling them out of the holder a piece of cake. I didn't fancy pulling out the whole lamp and risk damaging the headlining.
    RCO likes this.
