Map Light Wiring Diagram
Discussion in 'Gen 3 Prius Audio and Electronics' started by Ironworm, Dec 14, 2017.
  1. Ironworm
    Ironworm Junior Member
    Hello,
    I am looking to hardwire some devices and I found a power connecting the map/dome lights. Doing research the plug seems to be the J33 plug, does anybody have a diagram on which wires are hot with ign on and the ground wires?
  2. frodoz737
    frodoz737 Top Wrench
    4,798
    2,560
    33
    Can only help with the 2010 Model at present, but this may get you in the ball park.
  3. ErikJ
    ErikJ New Member
    23
    Palo Alto, CA
    2015 Prius Plug-in
    Don't know if you're still looking for this info, but here it is for a 2014:
    1 - GROUND
    2 - MICROPHONE -> SNS2
    3 - MICROPHONE -> MCO-
    4 - MICROPHONE -> MCO+
    5 - MICROPHONE -> MACC
    6 - BLANK
    7 - BLANK
    8 - GEARSHIFT ILLUMINATION +
    9 - SWITCH ILLUMINATION +
    10 - BLANK
    11 - DOOR SIGNAL FROM BODY ECU (ACTIVE LOW)
    12 - DOOR -> REAR DOME LIGHT
    13 - SAFETY CONNECT GREEN LIGHT +12V
    14 - SAFETY CONNECT RED LIGHT +12V
    15 - SAFETY CONNECT SOS BUTTON +
    16 - SAFETY CONNECT SOS BUTTON -
    17 - ON -> REAR DOME LIGHT (GROUND)
    18 - BLANK
    19 - COMMON -> REAR DOME LIGHT (+12V)
    20 - UNSWITCHED +12V
    AST53, anonymous and Ian Wong like this.
  4. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    I wired my dashcam from that connector. But I do not remember the pins
    Just try to find the largest one for ign
    Ground I think its white
  5. anonymous
    anonymous Member
    177
    104
    US
    there is no ign...
    ground is white with black stripe it appears
  6. anonymous
    anonymous Member
    177
    104
    US
    here's what it looks like without any of the extra features
    no ign, only constant 12v and gnd... no good for dash cam
  7. jimolson
    jimolson Member
    162
    63
    Indianapolis, USA
    In answering a question I posed to this forum in March 2025 I can now confirm that there is no unused wire harness pigtail in 2010's that are not shipped with the HomeLink mirror.
    And after following circuit board copper tracks under a microscope at my office I can confirm that there is no ignition switched +12V signal on the dome light's circuit board.
    However, for purposes of adding a Gen 2 HomeLink mirror to a 2010 I think the signal identified above as pin #8=Gearshift Illumination=White Map Light LED can be used to power the electronic dimming subsystem in the mirror.
    I think this line is +12V when the car is powered on AND the headlights are turned on, which roughly equals when the mirror's dimming system would need to be powered and active.
    I can't imagine that the dimming subsystem would require +12V when the headlights are off.
    This comment assumes that the mirror's unpowered state is unimpeded (not dimmed) mirror viewing, something I'm unsure of.
  8. rjparker
    rjparker Tu Humilde Sirviente
    11,063
    6,933
    Texas Hill Country
    Toyota never wires for uninstalled options available in higher trims. However I simply wired my dimming Homelink to constant 12v and Gnd years ago with no problems. Even factory Homelink systems still open gates and garage doors with switched 12v off. The dimming function has a 6 ma draw but my car is still under 30ma when shutdown.
    If you have a dealer retrofit a Homelink mirror they will give you a battery powered unit with no external wiring.
    MAX2 likes this.
  9. jimolson
    jimolson Member
    162
    63
    Indianapolis, USA
    For those of you attempting to attach a Prius Gen 2 HomeLink dimming rear view mirror to a Gen 3 Prius, the missing +IGN signal to drive the dimming feature of the mirror can be obtained from connector pin #8 Gear Shift Illumination +.
    This is the green wire in the connector shown in the above color photograph from poster "anonymous".
    On my bare bones 2010 Prius the shifter knob is not illuminated. Instead there is a single white LED that shines on the gear shift from the overhead console.
    Some people refer to this white LED as a map light, but its light output is too low to serve that purpose. The green wire in the console's 20-pin connector goes to +12VDC whenever the headlights are turned on. This signal powers the white LED in my 2010.
    When the car is turned off and the headlights time out, the green wire returns to 0VDC.
    The current sourcing capacity of the green wire is sufficient to supply 100mADC to the dimming subsystem in an auto-dimming mirror.
    BTW, when you harvest a dimming mirror from a junked Gen 2 Prius, get the wire harness, too. And take as much of the wire feeding the harness' connector as you can because the 20-pin connector is at least 18" from the mirror.
