Map not working
Discussion in 'Gen 2 Prius Audio and Electronics' started by Dodung210655, May 16, 2023.
  1. Dodung210655
    Dodung210655 New Member
    I have a Prius 2009, 210,000 miles. When pushing the "MAP" button, there is a sentence " the external system is not connected". So, I cannot use the GPS when driving. What is the problem and how to fix it, thank you.
  2. Tideland Prius
    16,642
    It's possible it didn't come with GPS (even though the wheel had the MAP button)
  3. dolj
    dolj Senior Member
    8,622
    4,376
    Wellington, New Zealand
    ... and if your car did come from the factory with GPS, someone has removed the navigation box from under the LH front seat.
  4. ChapmanF
    18,830
    Has it ever worked, while you've had the car?
  5. bisco
    52,630
    mine just quit altogether after 10 years
  6. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    The fix is to use your cell phone/tablet or buy a Garmin with lifetime maps. Toyota is no longer supporting the system and no updated DVD's may be provided by any third party so it is outdated and innacurate. Besides, the cost of a DVD update (when they were available) was more than the cost of a Garmin unit with lifetime map updates.
  7. Tideland Prius
    16,642
    Really? Mine still worked on my 2010. (I had the Denso unit if that matters)
  8. bisco
    52,630
    idk which one i have. when i press map, i just get the spinning circle forever.
    kinda like priuschat sometimes :p
    Tideland Prius likes this.
  9. Tideland Prius
    16,642
    Ohh... you probably have ScoutGPS or one of those Display Audio ones that Toyota experimented with.
  10. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    I have the map button on my steering wheel and get the same message...but don't have NAV. Car never did. I wonder if I can reassign the button with a PAC steering wheel adapter to do something else.(n) Maybe when I upgrade the HU to Carplay someday.:whistle: Turbo would be nice. Or smokescreen, or even a parachute? ;)
