MAP or MAF? And does it need maintenance?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mandolin, Mar 7, 2015.
  1. Mandolin
    Mandolin Junior Member
    Woodbridge, VA
    I took my 2011 Gen III to the shop the other day to have them change the inverter coolant and transaxle fluid. With 60000 miles, I've been okay for a couple of years doing everything else myself. Along with a bunch of other expensive "recommended maintenance" items that I rejected, MAP sensor maintenance ($62.50) was also suggested. Just an upsell? I've got no warning lights and performance is great.
  2. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    The MAF sensor is the Mass Air Flow sensor, and while I'm not intimately aware of where it sits on the 2011 engine, I know that "maintenance" involves spraying it with brake cleaner and putting it back in.
    Someone like @3prongpaul could definitely speak to it with more authority than I can.
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    The MAF sits between the air cleaner and the intake manifold. Its purpose is to measure the amount of air coming into the engine in order to mix the proper amount of fuel. As such, it is an extremely important component for efficient engine operation. I would also imagine it is quite delicate. As far as cleaning, it would only be warranted if the engine is running rough, I'd say.
  4. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    559
    Tucson, AZ
    2021 Prius
    If I were going to clean mine, I would only use a specifically marked MAF cleaner. Any residue that might adhere to the "hot wire" section of the sensor will affect its accuracy. Could even make its performance worse. Good guidance though to not fix what isn't broke. MPG decrease or engine performing roughly are clues. Could be other things too (air filter, plugs, bad gas).
    MikeDee and Mendel Leisk like this.
  5. Mandolin
    Woodbridge, VA
    Sounds like it would do a lot of good for the dealer but not much for me at this point. Thanks!
  6. practica
    practica Junior Member
    43
    Raleigh, NC
    The MAF can appear defective when only the air hose is loose -- since it detects air flow. After 60K miles an Engine Check Light code showed a fault in the MAF. The Mass Air flow meter is attached to the intake air cleaner. The air cleaner had just been replaced. Dealer found the intake hose loose and repaired at no charge. Dealer also said MAF replacement very rare on Prius compared to other cars. The sensor is the same type used for servicing building air conditioning vents, a hot wire anemometer. Temperature of a heated wire is measured by a thermometer with wind cooling it off. They work on low velocity flows compared to weather fan based meters and avoid moving parts. Dirt in it or baked onto the wire can distort the readings. There is special cleaning fluid for it sold in stores, but it cannot be rubbed due to delicate wires.
    Air flow is measured on all modern computer controlled engines to adjust injected fuel mixture. An abnormally low temperature from dirt blockage etc. can be used by software to detect faulty measurements and turn on the engine check light.
    The Check Light dumps too many things onto one indicator as it includes loose gas caps as well. Autozone stores, for one, will read the error codes for the specific fault detected free of charge. It seems with the MAF code, the unit needs inspection for the hose etc. before doing anything.
    monahj and bisco like this.
  7. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    The Manifold Absolute Pressure (MAP) is located very low in the engine compartment, on the intake manifold, next to the throttle body. But I doubt your mechanic is going to clean only the MAP without at least doing the throttle body while he's down there.
    Just to be clear: There is a MAP sensor, and a MAF sensor. Your mechanic is probably offering to clean the MAF sensor, which is really easy to clean.
    #7 Rebound, Dec 15, 2016
    ednorton likes this.
  8. Pete44
    Pete44 Junior Member
    48
    ONLY clean MAF sensor with MAF sensor cleaner (spray can from CRC or another brand). If you use brake cleaner, you must only very briefly and lightly spray it, and hope that you don't damage the polymer part that can disolve with brake cleaner and carb cleaner. The Car Care Nut on Youtube says to only clean if necessary and NOT to do this routinely as even just spraying it can cause inaccuracies.
    This is SUPER easy to do: MAF sensor is on top of intake plumbing and has two phillps screws. Remove these, unclip wire harness connector and lift out sensor. Spray clean and replace. It's a five minute job, if you include opening the hood and finding your screw driver and can of cleaner.
    I've over-cleaned mine (before knowing better) and am hoping it's still accurate (good gas mileage, but really hope my mixture is optimal). I don't have a good scantool to check the MAF sensor. Maybe I'll find someone who has one some day, that can check it for me (Arizona? Anyone?)
