Masking Tape on HV Battery Base?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TwoPriusInTenn, May 31, 2026.
  1. TwoPriusInTenn
    254
    66
    Tennessee
    Greetings All,
    Wondering the general consensus for putting masking tape between the cells on the base to solve electrolyte issues.
    I've seen several videos where this was done. Seems it might pose a fire hazard.
    Thoughts?
  2. PriusCamper
    PriusCamper Senior Member
    13,463
    5,431
    Pacific Northwest, USA
    No Consensus... Never heard of it and I started rebuilding battery packs 8 years ago. The electrolyte leaks from the seals when they're running hot where the terminals bolt to the bus bars. You can't stop this leaking and tape between the modules at the base won't do anything other than make the pack run slightly hotter.
    52,855
    google provided me with no hits or videos
  4. ChapmanF
    19,020
    Masking tape? Don't know about fire, but I wouldn't be surprised if it just soaks up the leaked electrolyte and conducts anyway....
    TwoPriusInTenn likes this.
  5. TwoPriusInTenn
    254
    66
    Tennessee
  6. TwoPriusInTenn
    254
    66
    Tennessee
    Here it is in living color.
  7. Hayslayer
    Hayslayer Active Member
    534
    325
    Rookies. There are many times where one of the metal inserts on the bottom of the module is exposed to the electrolyte due to a small internal crack in the plastic, but not actually leak electrolyte externally. This has been done quite often to insulate the metal insert from the case base. A bit of (usually) electrical tape underneath a module that has an insert causing a ground fault can clear a P0AA6 very inexpensively, of course the threaded fastener is also left off that module. Not a highly recommended solution, but completely understandable for a DIY that understands how electricity works. If someone doesn't grasp the concept of insulating a ground fault, then they probably don't understand what I'm describing.
    TwoPriusInTenn and Brian1954 like this.
  8. Tombukt2
    Tombukt2 Senior Member
    13,860
    2,519
    Durham NC
    I used zip tape I already have here . In rolls two strips at the contact points at on tray. trim and drop the racked modules . Nuts on plastic clamping device . Good to go did not let go dropping 12 feet off fork. Lift upside down . Nope no videos . This was fore all that
  9. TwoPriusInTenn
    254
    66
    Tennessee
    Yet, another use for Band-aids!!!
  10. Tombukt2
    13,860
    2,519
    Durham NC
    Zip tape is pretty good stuff. I use it out in construction several times a week .
