Massive Oil leak, broken oil filter housing base. Wear and tear or shop error?
Discussion in 'Gen 2 Prius Main Forum' started by Ohnocar, Sep 3, 2022.
  1. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Good photos @alftoy
    Shows more clearly exactly what I was mentioning earlier.
    @Ohnocar, in what state are you located?
    Ohnocar likes this.
  2. Ohnocar
    Ohnocar New Member
    Usa
    My car is parked somewhere new everyday and I worked after sundown. It was not all of a sudden. I’ve had to add oil at least 5 separate times since the oil change. Never seen oil on the floor…
    I thought the excessive oil was because I’ve been driving the car excessively since going full time with instacart and the vehicle is indeed old… the oil light would come on and I add oil the light is off. I go on about my business. I did find this weird because I’ve never ever had to top up oil before, I would get an oil change every 3 months at the same shop but again I was never driving this much either so chucked it up to that.
    It never crossed my mind that there was an issue with the oil change until the tow guy mentioned it to me.
    Idk if it started as a small crack and got bigger or what but by the time the manager came to inspect, as soon as he added oil it hit the floor immediately…
    I have liability insurance only ☹️
  3. Ohnocar
    Ohnocar New Member
    Usa
    It’s been leaking since the service. I’ve had to keep adding oil I just never put 2 and 2 together.
    I dont have a garage or driveway, I’m parked on nyc streets a different one every night sometimes within 5 blocks of my apartment if I’m lucky. No I didn’t notice oil on the ground I wasn’t really looking…
  4. Ohnocar
    Ohnocar New Member
    Usa
    I’m in Brooklyn NY
  5. Ohnocar
    Ohnocar New Member
    Usa
    never noticed any puddles of oil, but the oil light would come on and I would add oil I didn’t ignore it. I was indeed driving the car a lot more so figure that was reason for oil light. I should’ve known something was wrong because I never had to top up oil in the 6 years I had the car just oil change every 3 months same shop.
  6. Ohnocar
    Ohnocar New Member
    Usa
    So the oil filter housing or upper oil pan, do we all agree that these are not wear and tear parts?
  7. alftoy
    alftoy Senior Member
    1,132
    517
    Saskatchewan, Canada
    Yes wear and tear. Could've had a slight crack before oil change. Unfortunately you don't have any choice but to replace the upper oil pan or the engine. Probably better to replace the engine. Attached some Brooklyn salvage yards search for engine, maybe search using your Brooklyn zip. You may ask the salvage yard if they could install the engine.
    As noted regards check car-part.com for parts.
    #27 alftoy, Sep 6, 2022
  8. Mendel Leisk
    41,515
    Can someone verify: on 2nd gen the oil filter screws directly onto the "upper oil pan" casting. I wonder if that was a problem. Here's pics of 3rd grn (4th gen sim), where the oil filter attaches to a separate casting that bolts onto the upper oil pan casting:
  9. alftoy
    1,132
    517
    Do not confuse Gen 2 and 3. No separate casting.
    Oil filter screws on to a union (Part # 90904-04004) that screws into the upper pan casting boss.
  10. Mendel Leisk
    41,515
    Maybe the change with 3rd gen had something to do with cracking? Who knows...
  11. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    Castings do not flex. That's what is great about them, and what is bad. They hold their shape until enough force is applied they they have a catastrophic failure (like a crack). There is no way anyone could apply enough torque on an oil filter, tightening or loosening to snap that ear. If something like that did happen, there would be massive damage to the casting on all sides, not just the ear.
    It looks like the fastener is installed from the top. Is it possible it was over torqued? Is it possible the oring was not properly seated in it's groove during assembly and created a leverage point for the fastener to make the ear crack and it just finally started leaking?
    Have you ever installed a water pump on an older ICE engine? SOOOO many water pumps with cast housings that had ears. Same thing with thermostat housings. You NEVER torqued those fasteners unless you were 100% certain everything was properly aligned. Accidently leave some of the old gasket on the engine mating surface toward the pump side of the bolt? It prevents the surface of the new pump/gasket from mating flat to the machined surface of the block. That small "extra" gap when torquing the ear bolt can easily result in--->Snap as the fastener tries to pull the two pieces together. Because castings don't bend, they crack.
    douglasjre likes this.
  12. alftoy
    1,132
    517
    Looking at more photos of the upper pan. The bolts insert from below through upper pan into short block, all 13, notice the one bolt up through the filter casting.
    #32 alftoy, Sep 6, 2022
  13. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    Yup, I believe you're right. Should have thought that one through a bit. I have yet to see an oil pan that has a bolt go in from the top, lol. Studs yes, bolts no.
    It kind of brings up another question. This bolt can only be accessed by removing the filter and the threaded coupling that the filter spins onto. I wonder if some previous work was done on the car, with this bolt not getting removed. Perhaps some prying on the pan and eventually "crack", and the sudden realization there was a hidden bolt? Fix it quick, seal it up best possible and sell it?
    OP_ How long have you had the car? From where did you purchase it? Have you ever looked at the Toyota maintenance history to see if anything stands out? The Toyota history won't have any info from independent shops, but if someone brought it into the dealer for a problem evaluation, they would document it, whether work was performed to correct it or not.
    #33 TMR-JWAP, Sep 6, 2022
    Montgomery and alftoy like this.
  14. douglasjre
    douglasjre Senior Member
    2,181
    720
    Null, NL
    There's a reason the tow guy is called the tow guy and not a mechanic
    Yosarian likes this.
  15. alftoy
    1,132
    517
    Need to be a mechanic to check the oil? Or to notice the leaking oil. Seems to me tow guys have some mechanical ability to hook up vehicles.
  16. douglasjre
    2,181
    720
    Null, NL
    They don't. You don't know why they're tow guys. Trust me, the reasons are many. Nurses aren't doctors and they're not qualified to operate just by association with the OR
  17. douglasjre
    2,181
    720
    Null, NL
    LOL. Wrong. Try it. Ask him to check the oil. Watch him closely to see what he does. Sorry man. He's not qualified to check oil or determine the source of leaks. On your car sure, not mine. Front desk staff at he Dr ofc doesn't diagnose my medical problem either.
  18. douglasjre
    2,181
    720
    Null, NL
    I don't practice law but do you want my opinion on your legal matter? Up to you I guess but I personally go to the experts in every field. The wisdom you get is far beyond what you could imagine because you are naive. Bein gin this field we could share a few stories.
    My sig other is many states away for work and has on eof my Pri. A wheel bearing is going bad. I told her to go to the Lexus dlr. She exclaimed "Isn't that gonna be expensive?" I told her no, it's cheaper than paying to do it wrong, breaking down somewhere, paying a tow bill, missing a day or two of work, then paying to have it done the right way after all!
    Your car. Do what you must. For me to sound like this can you imagine all that I have seen?
    #38 douglasjre, Oct 31, 2022
  19. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    Well given your situation…. What if you cleaned it all off with engine cleaner then cleaned the crack with brake cleaner to remove everything. Then mixed up JB Weld and used a plastic syringe to inject JD Weld into the crack to seal it. I don’t think it would make it worse. Not sure what the oil pressure is but I have heard of radiators being repaired this way. Oil temp even though hot I don’t think it would be as hot as coolant fluid. 260 degrees? If the block is not cracked and the engine isn’t seized it might be worth a try.
    worse case it still leaks and you have to replace the upper oil pan anyway. I don’t think the oil change place damaged it.
  20. ColoradoBoo
    ColoradoBoo Senior Member
    1,241
    833
    Monument, Colorado USA
    Wow, sad story...I've never heard of the filter housing cracking like that. Without inspecting it it's only a guess why it happened.
    I have two daughters and have tried to tech them as much as possible about taking an interest in their cars...not just relying on a shop or others to do it. The old saying is true...if you ignore or neglect a small engine issue it WILL turn into a major engine issue. So knowing what's normal and what's not is very important....from sounds when starting and driving to smoke coming out to sequels and squeaks from power or loss of power...so many things!
    If the engine was ran with no oil, there's little hope of saving it....numerous parts are now ruined from the heat and need replacing if not the whole block. So sorry!
