Massive Oil leak, broken oil filter housing base. Wear and tear or shop error?
Discussion in 'Gen 2 Prius Main Forum' started by Ohnocar, Sep 3, 2022.
  1. alftoy
    alftoy Senior Member
    1,132
    517
    Saskatchewan, Canada
    Most PriusChat members aren't mechanics, what do you have to say to us?
  2. JahT
    JahT Member
    145
    77
    Just wanted to ask the OP if they heard any air tools at the oil change place?
    It is a stretch, but a 30 min place could be treating it like a pit stop and used a oil filter cup/socket tool and tightened by mistake with an air impact wrench. There could be obvious damage to the surface the filter seal against, or to the threads, that isn't seen until you remove the filter.
    You could sneak back and listen/observe their work to see if they are sloppy and obviously inexperienced. 30 minute oil change guys can make tow truck drivers look knowledgeable.
  3. Mendel Leisk
    41,384
    You’re way too optimistic.
    JahT likes this.
  4. JahT
    JahT Member
    145
    77
    Ha ha, at least it might get you more leverage with the manager or corporate if they were doing something weird. One of my friends first jobs was at a Jiffy Lube and I am sure he overfilled engines, stripped some drain plugs, and did some damage. Imagine a kid in a hurry hammering the air wrench wondering why it won't come off until it collapses the filter and maybe cracks the housing, then he finally realizes he was tightening and backs it off and puts new filter on. But yeah, no, probably not. Could just be a spontaneous crack.
    Mendel Leisk and douglasjre like this.
  5. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
  6. douglasjre
    douglasjre Senior Member
    2,177
    717
    Null, NL
    Chinese crap will ruin everything
  7. akshara837
    akshara837 New Member
    india
    great try. i like your efforts. god bless you sad dp
  8. douglasjre
    2,177
    717
    Null, NL
    All shops over tighten. The misperceive the sealing surface. It's an o ring inside a bore. Don't even need to bottom the cup. Jiffy lube uses paraffin that looks like oil. If you like your engine you won't go there. They destroy pentastar oil cooler assy's the same way, crank down on cap
