Master, engine, VSC and engine lights all came up at the same time
Discussion in 'Gen 2 Prius Technical Discussion' started by riceroni4, Mar 11, 2014.
  1. Patrick Wong
    18,210
    6,526
    Yes, but the OP won't be able to do anything about her car's problem without visiting her dealer since she says local repair shops won't work on hybrids in post #1. Her car's problem is not a minor one.
    Since she reported very little fluid turbulence in the inverter coolant reservoir in her post #13, it is possible that the root cause of her car's problem is a failed inverter coolant pump or the need to purge air out of the coolant system. This may have caused the inverter to overheat and the DC/DC converter to fail solid.
    Sometimes the DC/DC converter will resume its functioning after the inverter has cooled down. This apparently is not the case with the OP's car, since she continued to get low voltage readings on the 12V bus when the Prius was made READY, last night.
  2. JC91006
    16,936
    8,647
    I was reading this thread this morning and my wife thought I was chatting it up with another woman online. That selfie picture the OP has on her profile is really distracting.
    Back to the topic, it's great how Patrick is able to diagnose the car. I knew the voltage readings were off but didn't know the cause. Wonderful learning experience.
  3. riceroni4
    riceroni4 New Member
    24
    Perry, Florida
    Brought it to have the battery changed out and started the vehicle and all lights were gone and car ran perfectly until I stopped at a store then the car started the same way..I disconnected the battery and reconnected and car was fine again. Could it be the wiring?
  4. JC91006
    16,936
    8,647
    When you disconnect the battery, the ECU computers all reset and you are able to drive the car until the computer detect the problem again. Disconnecting the battery does not solve your problem.
    I think Patrick had ruled out your battery being a problem with a 12.4 voltage reading when on. You didn't need to replace that battery.
    Has your car done the recall on the inverter water pump?
  5. riceroni4
    24
    Perry, Florida
    The inverter was also checked in ready mode and it was normal. The hybrid battery seems to not be getting a charge as they put it
  6. riceroni4
    24
    Perry, Florida
    I won't apologize for my Facebook profile photo being used to post in this forum. I came here for some help with my prius not be judged by my photo.
    dorunron likes this.
  7. JC91006
    16,936
    8,647
    Where did you bring your car for service? Hybrid shop?
    What is the VIN# on your car? I'll help you find out if you've done the recall on the inverter water pump
    In November 2010, Toyota announced a “Limited Service Campaign” (number A0N) to replace inverter water pumps on 04-07 Prius. The reason, they stated, was the possibility of an air bubble getting stuck at the pump, reducing flow and causing the inverter to overheat.
  8. JC91006
    16,936
    8,647
    Nobody is judging you, I mentioned what my wife thought when she saw me respond to your thread with your picture on it.
  9. riceroni4
    24
    Perry, Florida
    JTDKB20U867536986 the shop here is a mom and pop and don't specifically deal with hybrids but have worked on them. I went on the recall website for Toyota and put the vin in but nothing came up
  10. JC91006
    16,936
    8,647
    This is on the history of your vehicle, dated 1/11/14
    CUSTOMER STATES THE CHECK ENGINE LIGHT HAS ACTIVATED. DIAGNOSE A ND REPORT. ~|~CODE P0A80 AND P3015 FOR WEAK HYBRID BATTERY ~|~WILL NEED TO REPLACE AUXILLAR Y BATTERY $239.95+TAX AND HYBRID HV BATTERY $2998.95+TAX CUSTOME R DECLINED REPAIRS AT THIS TIME. CUSTOMER ADVISED VEHICLE WILL B REAK DOWN SOON.
  11. JC91006
    16,936
    8,647
    your car has an extensive repair record with Toyota, it's been well taken care of. All recalls have been done. I'm assuming you purchased this car after 1/11/14, the only reason the previous owner sold the car is because of the P0a80 code diagnosed by Toyota, which means the hybrid battery needs replacement. It mentioned the 12v needed replacement as well, so not sure if they replaced it before you bought it. But since you replaced it again today (hopefully with a proper AGM type battery), it shouldn't be an issue anymore.
  12. riceroni4
    24
    Perry, Florida
    Oh wow thank you so much for looking that up I bought the car after that date yes
  13. JC91006
    16,936
    8,647
    You can access all the records for the car yourself. Go to Toyota.com, click on the "owner" portal. There you register and add your vehicle with the VIN#. All the information is there for you.
  14. riceroni4
    24
    Perry, Florida
    Thank you so much for your help. I am looking into getting the battery replaced now.
  15. riceroni4
    24
    Perry, Florida
    Update: after researching the cost of the hybrid battery through part number, I have had one ordered for $900 through napa and will have it in a few days.
    usnavystgc likes this.
  16. JC91006
    16,936
    8,647
    Napa has a $900 battery? Warranty on it?
  17. JC91006
    16,936
    8,647
    You should also verify that your DC/DC converter is working properly. If the battery readings you mentioned when the car is "Ready" is correct at 12.4 volts, you might have a bad part. which is another expensive part. Hopefully it's just the battery that's bad and not more.
  18. JC91006
    16,936
    8,647
    What's strange is that you were able to drive your car for a few weeks without problems. I'm wondering if the previous owner actually did repair the HV battery before selling it to you. Without properly diagnosing this car, you could be buying a battery prematurely.
    I don't want to suggest the battery is bad based on a service record from Toyota. Just want you to be aware, this was a recent problem in January. $900 is a lot of money if that's not the cause of the problems you are experiencing.
  19. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    FWIW, I would take the time to visit a Toyota dealer and pay for a diagnostic to have the codes pulled BEFORE I ordered any parts for your car.
    So far we have learned that the inverter does not seem to be functioning ALL of the time. This could be caused by the inverter pump not working properly. Remember you did say you saw bubbles. No bubbles should be present. Also you did state that the voltage was 12.4 in Ready Mode which would demonstrate that the DC to DC converter was not working at the present time.
    Furthermore, you have reported that the fan in the back is running and can be heard. That also indicates a possible problem with the battery, but could just mean that it is hot because the fan motor is plugged up with lint. The P0A80 codes does demonstrate a battery problem and the P3015 does demonstrate a weak module in the battery.
    To make a long story short, I have a feeling that you have more than one problem that needs to be addressed.
    IMO, it would be worth the money spent to pay a small diagnostic fee to Toyota BEFORE proceeding with ordering any parts or attempting any repair on your car. Throwing parts at it is not the way to try to fix a car. A proper diagnosis before hand is generally the best approach in any vehicle repair project including your Prius.
    Don't be surprised that in the end you pay for a new 12 volt battery, a new or rebuilt traction battery, a inverter pump or bleeding thereof of the pump. Since you have stated that the voltage rose to the normal amount the following day it appears that the inverter had shut down due to overheating. This happens when the inverter pump is not operating properly.
    I wish you the best of luck with your Prius. Sometimes this is what happens you buy a used car. It seems pretty evident to me that the seller sold the car knowing it had problems, but did not fully disclose to you the history of the car.
  20. riceroni4
    24
    Perry, Florida
    I contacted previous owner and the hv battery was not replaced not the 12v battery or rear brakes. The 12b battery was changed this morning and the hv battery will need to be changed out with the codes that came up. I am having the shop that's ordering the battery check with the scanner that's needed for these codes to make sure. I would be furious if the hv battery was not the issue. I will have to look up the amount the warranty covers on the battery
