Master Switch Not Closing Rear Window After Door Replacement
Discussion in 'Gen 3 Prius Technical Discussion' started by Slavatheshrimp, Apr 21, 2020.
  1. Slavatheshrimp
    116
    73
    Mather
    I have a 2015 PIP with non JBL speakers. I purchased a door with a JBL speaker. The master regulator doesn't open or close that specific door but works on the rest of them. That JBL door switch works.
    Would it be a harness issue? I could swap the harness but I am not quite sure what can be the problem. Is there a way to "register" that switch with the rest of the doors?
    I did the 5 second down and 5 second up to set the window but that's all I've done.
    Thanks.
    UPDATE: Switching the original harness solved the problem.
    /closethread.
    #1 Slavatheshrimp, Apr 21, 2020
    Raytheeagle and bisco like this.
    52,693
    well done!(y)
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    Always good to fix the problem yourself my dude:).
    Congrats(y).
  4. Slavatheshrimp
    116
    73
    Mather
    Thank you guys, for believing in me. Hahaha
    Raytheeagle likes this.
