Master warning light comes on when driving up hill
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mark J, Nov 7, 2016.
  1. Mark J
    Mark J New Member
    Washington state
    Hello I have had my 2006 Toyota prius for about 6 years now. I bought it used and it had been in a drivers side front end car accident before I bought the car. I have had very little problems with the car until moving to Washington state. I moved here a year ago and have been driving up into the mountains. A couple months ago I was driving to Seattle on the highway going about 70 mph and the Red triangle light came on. Along with the check engine light. The car then slowed down to i think 37-38 miles per hour. I pulled over and turned the car off. Sat there for a few minutes them turned the car back on. It worked fine for the rest of the 70 miles I drove it to get home. Then it happened again while not driving up steep hills it was mostly flat highway. Two weeks ago I was driving it up the mountain highway and the same thing happened. The car had a funny smell coming from the engine area. I pulled over and turned the car off for a hour or so. When I came back and turned it back on the warning lights were still on but the car could accelerate past the 38 mph. Drove it home about 60 miles no trouble just warning lights on. I wake up the next day and the warning lights are off. I am so confused as to what may be wrong and would love some help solving this problem. Thanks for everyones advice I appreciate it :)
    I have not taken it in yet for a computer scan tho...
    This may be my problem?
    52,390
    welcome! you need to have the trouble codes read. how many miles on her?battery could be on the way out. how many miles on her?
  3. dolj
    dolj Senior Member
    8,559
    4,349
    Wellington, New Zealand
    Did you check your oil level at any of these times? Was it low?
    Have you checked your inverter reservoir for turbulent movement of the fluid? If there is no movement in the reservoir your inverter water pump has failed.
    #3 dolj, Nov 7, 2016
  4. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    In addition to the above, have you ever serviced the engine cooling system? Do you know how to check coolant levels in both systems?
    A ten year old hybrid battery seeing heavier duty cycles in the mountains could be a problem.
    Without trouble codes, we're just guessing. You'll probably need a Toyota-specific scan tool to retrieve the appropriate codes for the hybrid system.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Have you ever opened the hood?
    Bluegrassman likes this.
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    I would agree with checking the oil level first. Check it while park on a level surface.
    Once you get it scanned and have a code, post it here.
