Master warning light just after stopping the engine
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Chamara Somarathna, May 23, 2018.
  1. Chamara Somarathna
    Chamara Somarathna Junior Member
    Sri Lanka
    I have a 3rd gen prius and when I turned off the engine the master warning light illuminates with a beep sound and after a couple of seconds all goes off. This happens not in every time but happens randomly. What would be the problem? Your assistance would be highly appreciated... Thank you.
    P.S: all the doors were closed and the car was in the parking gear.
  2. sapumal
    sapumal New Member
    colombo
    Three Touring
    change the smart key battery and check.......
    49,378
    read the trouble codes.
  4. bsnf
    bsnf Junior Member
    Raleigh, NC
    What was the resolution to this problem. I am experiencing the same problem on my car.
    Your reply will be greatly appreciated.
  5. bisco
    49,378
    check the fob battery voltage
  6. bsnf
    bsnf Junior Member
    Raleigh, NC
    Thanks. I changed the battery on the smart key and did not see the issue today morning.
    I will continue monitoring and if I see it issue again, will get the car checked in a Toyota repairs shop.
