Master Warning Light ON for no reason
Discussion in 'Gen 2 Prius Main Forum' started by Catalinux, Nov 20, 2012.
  1. Catalinux
    Catalinux Junior Member
    43
    Romania
    2013 Prius Plug-in
    Hi all,
    I have one of the most strange problems on my car, for absolutely NO reason when i turn the steering wheel on a curve to the left after 45 miles/hour, or brake from 62-65 miles/hour on a straight line the MASTER WARNING LIGHT (the red Triangle, the death triangle as mentioned by some membres) comes ON for 1 to 2 seconds and then goes OFF, NO DTC found, the car is running OK, all the fluids are at the specified level. I suspect something wrong with the electricals, if you have similar problems please give a reply. It is a Europe Prius Gen II from 2006 with 100k miles on-bord, thank you.
  2. Patrick Wong
    18,200
    6,479
    Although you say all fluids are at specified levels, check the engine oil level using the dipstick after the car is IG-OFF at least five minutes, on level ground.
    [email protected] likes this.
  3. usnavystgc
    3,159
    989
    Tucson, AZ
    Yep, I'll bet you're low on oil.
  4. Catalinux
    43
    Romania
    2013 Prius Plug-in
    Yep, don't bet because you'll win :) , the level of the oil was low, and then i studied to see if it has a different warning for low oil pressure or level and it doesn't have, so both of you were wright. Problem solved, thanks guys !
    usnavystgc likes this.
