Master Warning Light, P1121, and P1123
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sugaraddict, Feb 21, 2021.
Tags:
  1. Sugaraddict
    Sugaraddict New Member
    Hey there all,
    I bought my 2005 Prius last year, its my first car, and I've already fallen in love with it. A little while after purchasing the check engine light came on, and the dealership (after taking $200 for the diagnostic fee!) told me it was giving them the P1121 error, and that the coolant control valve had to be replaced. I rode around on it in the past months since at first I didn't have the money for any kind of repairs, and now that I do, work has a much too firm grasp on me and I have 0 free time. It's at ~151k miles right now and I've driven it less than 2k miles in the time I've had it - my workplace is really nearby. Also, the battery was replaced upon purchase by the dealership because there was some sort of issue with it.
    I was affected by the deep freeze the south experienced this past week. Everything was okay for the first few days, but on Thursday evening when I was coming home from work, I turned my car on as usual but then the master warning light, VSC, and (!) lights all came on at the same time and stayed on. I'm sure part of it was due to the cold; this morning the VSC and (!) lights turned off, but the master warning light is still on. Using a diagnostic tool from Autozone I was able to pull the codes P1121, but now also P1123 which wasn't there before.
    Is it safe to drive on this, at least until I get the replacement part and I find someone who can install it for me? I don't really go above 35mph and my drive to/from work lasts maybe 3 minutes. Nothing really feels any different, the heating works for sure and breaking/accelerating/turning feels fine as normal. The light consistently says on when I turn the car on and when I drive though, no flashing or anything. I've seen some people recommending that I check on the coolant and oil too. Would those be necessary considering I use my car so infrequently? (And if I flush the coolant - is there anything in particular I need to do to make sure I'm disposing the fluid correctly? Where does it go when I flush it? I don't have a garage or any sort of space or tools to do something like that :oops: Reckon someone at Jiffylube could help me if I stroll up with my bottles in hand? lol)
    Sorry this turned into a novel - I'm a bit long-winded and I wanted to be as detailed as I could!
    52,863
    welcome!
    if you're getting cabin heat, there's no rush to replace the coolant control valve. try to find a local garage who can do it, it is pretty simple.
    start by making sure you have a healthy 12 volt battery. most any auto parts store will load test it for free.
    post the results here. alow 12v from sitting in cold weather can confuse the computers.
    if you aren't driving much, you may need a battery maintainer to keep the voltage up. the car needs to be driven quite a bit to do that.
    if the 12v is fine, we can move on to trouble codes.
    how many miles on your car? it is always necessary to check the coolant and oil 'levels'. you should learn how to do that, and keep an eye on them regularly.
    do not flush the coolant, and i won't need to explain what that means. :)
    go to 'toyota.com/owners' and plug in your vin. check the service history, and then look at the maintenance interval manual to see what needs to be done to the car if anything.
    warning: do not go to jiffy lube
    all the best!(y)
    #2 bisco, Feb 21, 2021
  3. Sugaraddict
    Phew, I'm glad I don't have to rush it. Here I was thinking that after driving on a check engine light for so long, the master warning one came on because it finally had enough of my procrastinating :LOL:
    I'll definitely have to get the battery checked out then, hopefully on Tuesday if I can find someone willing to check it. It seems like everyone around here is too scared to even look at hybrid vehicles lol. I didn't know about battery maintainers though - are there any particular ones you would recommend?
    The mileage is at 151,000 right now, got it at just shy of 149,000 last summer. I should ah, definitely check the oil levels though. Its something I completely forgot about! Nothing is showing up when I plug in my VIN on Toyota's site though, and now of course my internet is being slow and the free VIN checkers aren't working. I am seeing that I should get it checked every 6 months if I don't hit the 5,000 mile mark in that period though.
  4. ChapmanF
    19,038
    Also may be worth mentioning that the coolant control valve is one of numerous parts of a Prius that have potentiometers used as position sensors and sometimes needing a bit of tender loving care. Sometimes the TLC, instead of outright replacement, may be all it needs.
    Sugaraddict likes this.
  5. Sugaraddict
    Just checked the 12V battery readings in vehicle signal check mode. With just having the power on I got 12.2V, turning the ignition on and leaving my foot off the break gave me 11.8V, but putting my foot on the break and fully turning the car on gave me 14.6V. Could that be the culprit, even though its mostly over 12V?
  6. dolj
    dolj Senior Member
    8,652
    4,402
    Wellington, New Zealand
    Sounds pretty common to me. The 11.8V means your battery is pretty discharged and the 14.6V means the DC/DC converter charging circuit is working. Being at the top end of its voltage range confirms also your battery is pretty discharged.
    Do you mean the reason for the P1121 and P1123 codes? Definitely not. The battery needs some TLC but it is a completely separate issue.
  7. Sugaraddict
    I see, thank you. Do you think I would be able to save it with a battery maintainer? Or would it have to be replaced at this point? I'm probably gonna trade it up for a newer Prius sometime within a year or two honestly; reckon it can last that long?
  8. dolj
    dolj Senior Member
    8,652
    4,402
    Unlike some here, I do not have a crystal ball, so I have no way to make that call.
    You would need a charger, not a maintainer.
    To see if it charging might help, put the car into IG-ON mode and also put the headlights on then watch the voltage on your voltmeter. If the voltage settles and remains steady in the 11V range (or above) then you have a good chance of just charging. If not, it will need replacing.
    To ensure your 12V battery lasts for a good long time and if your car is not being driven regularly, use a charger once every two weeks to keep the battery fully charged as much as possible.
