Max charge level dropping
Discussion in 'Prime Main Forum (2017-2022)' started by Steven Blinder, Nov 28, 2017.
  1. Steven Blinder
    Steven Blinder New Member
    Athol, MA
    So I bought my car on 10/13, and using a 30amp GCFI outlet at home, it has consistently charged up to a level of 25.7 or 25.9mi EVERY night. That all changed 3 weeks ago, and it started dropping to about 21-22. Dealer says the issue is known to Toyota, and possibly related to cold weather, but there is no resolution yet. Has anyone else experienced this?
    HPrimeAdvanced likes this.
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    yup, there's many many threads on this very same issue:D
    fotomoto likes this.
  3. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    Yeah it’s the cold.
  4. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    seems quite normal behavior, read some of the other posts from folks in colder areas of the country. Also EV range displayed is an estimate based on your recent driving characteristics ...
  5. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    If I'm not mistaken, the "charge level" you're describing is the EV range "estimate" that the Prime determines you can attain under the current conditions of weather, speed, acceleration, altitude, etc., and your general driving habits. In very cold weather, many people posting here report a reduction of this estimated range. This is probably due to lowered efficiency of batteries at low temperatures, and of course your driving style, including your probable greater use of heating which will reduce this estimate. If you scan through the posts here under Prime categories, you'll probably find more information on this question. BTW, congratulations and welcome to PriusChat!
  6. fuzzy1
    10,710
    Resolution is 5 to 6 months away, when warm spring weather arrives, wet roads dry up, and you quit using any cabin heat.
    fotomoto and HPrimeAdvanced like this.
  7. Garmy
    Garmy Junior Member
    68
    I quests this is Toyota’s answer to, “Why there are no Primes for sale in the Southeast”. Go figure?
  8. DavidA
    2,349
    1,825
    Chicago western burbs
  9. bisco
    52,858
    welcome to priuschat!
    dealer was telling truth, it is a known issue, and there is no resolution. are you pre conditioning the battery?
  10. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    All electric vehicles suffer from the effect of the cold. (to some extent even conventional vehicles as well but it is less noticeable).
    In addition to any possible limitation in the batteries the car requires more energy for driving as the temperature gets lower (or too high).
    Kevin
    This is an example for the Chevy Volt:
    Electric Range for the Nissan Leaf & Chevrolet Volt in Cold Weather
  11. bisco
    52,858
    don't feel bad, i'm down to 11.9 miles.
  12. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Interesting. My Prime on top. By the time you get down to 30 degrees, they're about equal.
  13. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    PC should start a "First post of the Season" lottery each year; see who's pick is the closest or actual date.:coffee:
    priuscatprimeguy likes this.
  14. fuzzy1
    10,710
    ... and as the road gets wetter (snowier). All that water getting pushed aside from the tires represents a significant energy loss. The more water, and the higher speed that its gets thrown, the more wasted power required.
  15. kevinwhite
    333
    200
    Los Gatos Ca
    I agree - in my Gen 2 Prius rain used to drop my mileage a few mpg. I haven't had much experience in my Gen 4 yet to know how much.
    In my Spark EV rain and cold would drop efficiency from 6 or 7 mi/kWh down to 3 or 4 mi/kWh.
    And it doesn't even get very cold here in the Bay Area so I wouldn't need put the heater on much, the biggest issue was keeping the windshield from fogging up, that's one place where it's nice to have the 'free' heat in an ICE based car.
    kevin
