Max HV Battery Life
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by evenjack, Mar 23, 2005.
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    And you missed Jimbo's point, which was to install a good used battery pack, not a failed battery pack. The point is that the number of wrecked Prius with good battery packs is much larger than the number of failed battery packs. This means there is a surplus of good used battery packs available at bargain prices.
    Tom
  2. richard schumacher
    7,686
    1,068
    United States
    How does one identify them?
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Sandy was giving one out for free and nobody needed it.
  4. mike lipke
    mike lipke New Member
    89
    MN
    "How does one identify them?
    With a voltmeter.
  5. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    Still have it Missed Hobbit while he was down here.
  6. richard schumacher
    7,686
    1,068
    United States
    Is it really that simple? I suspected that one would have to test each cell individually.
  7. qbee42
    18,058
    3,081
    Northern Michigan
    Testing each cell would be the most accurate method, but testing the pack as a whole will give you a pretty good idea. Any bad cell will bring down the total voltage: a bad cell will never exceed its nominal voltage, but will usually read lower than nominal. If the whole pack reads at nominal, then things are promising.
    What you can't tell is the health and balance of the cells. As with anything bought at salvage, you either get a good warranty or take your chances.
    Tom
  8. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    sandy, check your PMs.
    _H*
  9. RodThorp
    RodThorp New Member
    Tehachapi, Ca
    I was just told today by a dealer in Bakersfield, Ca that I needed a new battery.
    I had not really seen any bad symptoms, but suddenly the hybrid warning
    lite went on.
    Price the dealer quoted was $3600.00. I did not go for a new one. The car
    seems to run fine.
  10. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Are you over 150k miles?
    In CA, I believe hybrid battery is warranted for 10 years or 150,000 miles.
    Ken@Japan
  11. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    1. Are you the original owner of this car?
    2. If so (or if not) do you know if this car was purchased in California?
  12. David St. Hubbins
    David St. Hubbins New Member
    Greenville, SC
    I just posted my HV Traction battery failure and replacement on another thread for our 2007 with 57,000 miles on it. Wow, 1 in 40,000? where does that data come from? I guess I should play the lottery...maybe win a thousand or so with my recent "luck" of being 1 in 40,000.
