Max MPG Driving Techniques Youtube Video
Discussion in 'Gen 3 Prius Fuel Economy' started by RadioMan, Apr 13, 2010.
  1. Canard
    Canard Member
    223
    Ontario, Canada
    I would love for someone "in the know" to put together a "How to minimize fuel consumption in cold weather" video. :)
    -Iain
  2. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    I just have a question for y'all.
    At highway speeds, when you are above the speed where the ICE must spin to protect MG1 from overspinning, is there still a good reason to go into regen briefly before going into Glide?
    I understand in regular stealth mode that you want the ICE to stop, so you engage a little bit of regen to force the ICE to stop.
    My thought is, in warp stealth, the ICE has to spin regardless, so by simply easing into glide without ever going into regen first, the HSD would simply cut fuel to the ICE. Right?
    I don't have a scanguage so if someone can confirm the above that would be great. Also what is the speed at which the ICE must spin regardless?
    VLAM87 and walter Lee like this.
  3. natlaw01
    natlaw01 New Member
    Virginia
    Wow, this was great. I figured out a lot of this in the past week of driving...having attained a 54 mpg on a trip from VA to NY...:cool:
    I love this car so much!!! Just got my 2011 Four with solar package lat Saturday! Replaced my sweet Infiniti FX, but nothing is sweeter than getting triple the miles and paying a third for the gas...let alone the cheaper car note!
  4. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    Correct, no need to use regen if you don't have to. Of course, it's so slight, but it will slow you down a little at a time when you're trying to maintain momentum. The Gen III I believe you can just let up gradually but not fully on the accelerator as you say, which is different than Gen II which requires a full, quick release of pedal before redepression.
    Note what Wayne says here about warp stealth in the Gen III, that there are a couple warp stealth states, one of which consumes fuel. Scroll down to the small Warp Stealth section a little ways down.
    2010 Prius-III P&G, SHM and WS FE techniques rehashed, defined and refined - CleanMPG Forums
    Also in Gen III, ICE will run at and above 46 mph.
  5. NorthStarDaddy
    NorthStarDaddy New Member
    Thanks. This is great info for a brand new Prius owner.
  6. srivenkat
    srivenkat Active Member
    596
    93
    IL
    Many thanks for the great video!!!
  7. jasoninmass
    jasoninmass Junior Member
    52
    Boston MA
    great video...I dont know how you produced that with such detailed pics or who edited it..but fantastic quality. Awesome tips!
  8. DSharpe
    DSharpe Junior Member
    Hi Bob and thanks for the video. I'm from Canada and just purchased my first Prius - it's a used 2010 base model with 19000 km. I'm interested in seeing what mpg I can achieve and your video certainly helps. Some of the techniques, I have already been using, such as P&G, but my gas mileage seems to be around the 44 mpg mark. The weather this time of the year is around the freezing point so i'm hoping that that is the reason for the low mileage. I have 35 lbs in the tires, which I think is enough.
    Thanks again.
    Dennis :)
  9. john.ronald
    john.ronald Junior Member
    Sweden
    Thanks RadioMan!
    Excellent video and superior presentation. You should be a teacher:)
    Thanks again all the way from Sweden.
  10. rebenson
    rebenson Member
    364
    43
    Suburb of Chicago
    I just saw this earlier today (when i looked at a different issue).
    great video, thanks.
  11. mlg779
    mlg779 Junior Member
    63
    Buford, GA
    I went to 40 LBS in the tires and the mileage went up; my last tank of gas was 59.3 MPG. In the winter, here in Georgia, I was between 50 -52 MPG, but the car was also brand new and now I just passed 5000 miles.
  12. goodtimes
    goodtimes my future is righteousness
    67
    32
    2011 Prius Alpha
    That is definitely what a newbie needed... Thank you
  13. dairack
    dairack New Member
    los angeles, ca
    how often would you guys say that you have to fill up your gas tank? this question is directed towards moderate drivers
  14. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    It depends on how far you want to push it and what mpg you have been getting on that tank. If you drive till the low fuel light comes on then a Genii can go about 500 miles at 55 mpg. The geniii can't go a bit further due to the lack of a bladder fuel tank. I would say between 500 and 600 miles for most drivers assuming a 50mpg-55mpg average and a usable tank size of 10.5 gallons and not pushing it too far on empty. Those 70mpg freaks can get 700 or more on a tank.
    My highest was 531 miles at 55mpg.
  15. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    A hard question to answer (how often to fill up) without specifics. Generally speaking, F8L is in the ballpark. I think for most people, 450 +/- 50 miles would be a very conservative bet. If you go to Fuelly | Share and Compare Your MPG, you'll see a spread of average MPG reported. Pick a number (47 mpg is a popular number for a 2010). Multiply it by 10 gallons and you'll get a very safe/usable range in most circumstances (very cold winters, very short trips.....are exceptions).
    I typically fill up at 600 miles during the Summer/Fall months when I get my best MPGs. In winter, it drops to 500 miles, due to the combination of winterblend gasoline, colder temperatures, and rain.
    I just had my best tank (66+ MPG) and drove nearly 690 miles on it (put in 10.25 gallons, still had over 1.5 gallons in reserve).
    VLAM87 likes this.
  16. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Thanks, Cody. BTW, I included you in the 70mpg freak category. :)
  17. AStuke
    AStuke New Member
    95
    Metro STL, MO
    THank you! As a new Gen III owner. This was very informative to me as I recall the 09's needing a lot of attention to the "sweet spot" on the pedal for coasting- the 11's not so much.
    Thank you again for the video!
  18. AdrianMBrown
    AdrianMBrown Prius Owner Prospect
    16
    Seattle, Washington
    Great Video! It almost seems like you are an actual Prius school teacher. Anyways, thanks!
  19. d0nsut
    d0nsut New Member
    28
    Houston
    I am a new gen3 owner (3 weeks as of this post.) I was having fun trying to get the 5min times up over 50mpg. I finally got a few to 55 and was quite pleased. After watching this video at work, my drive home saw two 75's and a 60. The best part, I was driving with the flow of traffic and not impeding it or irritating those around me. This was an extremely informative video and the techniques can be implemented instantly.
  20. pjay
    pjay New Member
    99
    Westchester, N.Y.
    Thanks, Bob, for the video. Very informative and interesting to this first-time Prius owner.
