Max speed in Neutral allowed by Prius C
Discussion in 'Prius c Technical Discussion' started by Maxwell61, Apr 10, 2012.
  1. Maxwell61
    Maxwell61 Active Member
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    Someone could kindly take a look on the Prius C user's manual about the max recommended speed of the car in Neutral?
    There's any difference in coasting in Neutral relative to older Prius gens (apart max speed)?
    Thanks
    Max
  2. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    having the car in neutral doesn't do anything... and takes away any ability for the car to recharge the traction battery...
    coasting in neutral can actually hurt your mileage.. the best method is to "glide" if you're looking for something along those lines..
    and.. there's no max speed for a car in neutral.
  3. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Incorrect. In the Prius, if you enter neutral with the engine off (below 42mph) and then glide in neutral to above 42mph, you will be over-revving an MG causing damage. This can be done easily by gliding down a hill and gaining speed.
  4. fuzzy1
    10,673
    ^^ This is the GenII threshold. The standard GenIII threshold is 46 mph.
    I believe OP's question is, what is the corresponding figure for the Prius c? Because of powertrain and gearing changes, it seems unreasonable to assume that 'c' and 'v' thresholds are the same as either prior version.
  5. Maxwell61
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    This is exactly what i meant as max speed allowed, i.e. without crashing MG2 (i think or MG1 dont remember) for overrevving..... On our italian Prius forum i've been told GenII, have a threshold at 70 km/h (43,5 mph) and gen III at 100 km/h (62 mph).
    This is what i thought fuzzy, hence my question, but probably the answer can come only from a Prius C user that used to own some previous Prius gen and is already into HSD misteries. :)
    Of course i posed the question to exploit a condition of coasting in neutral with the engine off. I know many people does'nt recommend to drive in this condition and in US is even unlawful in some state, but this is not the discussion i was willing to make here.
    I found out the Prius C owner manual here in the forum and read it but sadly i found no clue for an answer. I'm wondering how older Prius gens owners determined the said speed. Toaster how do you know the 42 mph figure?
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Just a bit of clarification, in my Gen 2, I can use Neutral at any speed.
    What I should not do is go into Neutral below 41 MPH and let the car speed up above 41 MPH. It cannot start the engine in that one scenario, and it should.
    It is OK to use Neutral above 41, it is OK to use Neutral below 41, and it is OK to coast down from above 41 to less than 41. Just don't speed up.
    (Someone with a c could try to cruise at different speeds and discover what the fastest you can go on battery alone is, that is your threshold speed)
  7. Maxwell61
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    Correct, thanks for pointing out precisely, i see many owners of Prius C new to the hybrid world in the forum, its wise to warn about it.
    Nonetheless, it would be interesting to know what is the speed threshold for the Prius C revised HSD.
  8. SquallLHeart
    826
    247
    San Jose, CA
    oh.. that that point.. i do believe it is 45 mph before the ICE is needed to come on to protect MG1
  9. Maxwell61
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    Thanks Squall, and sorry if i was a bit criptic in my request. How did you evaluted the 45 mph?
  10. SquallLHeart
    826
    247
    San Jose, CA
    it seems to be the borderline that I have noticed while I'm doing pulse and gliding where I can get the ICE to stay off and stay in EV mode.
    anything faster and the ICE comes on.
  11. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    here is my minority opinion: dont do it! whats the point. nothing gained. may mess with the car a little. what is the point. sorry, i could not hold back any longer. lets see now... can i shut off my car at 65 mph and gain anything. maybe a new thread.:):)
