Maximum Amp Draw
Discussion in 'Prime Plug-in Charging' started by Ferrarilover, Jan 8, 2018.
  1. Ferrarilover
    Ferrarilover Active Member
    185
    168
    Manchester, UK
    Hi. I am hoping that you can help.
    What is the maximum draw from the Prime please? I know that I can set it to 8 amps manually but if I leave it on the max what does that pull? I believe on the older Plug In it was 12 Amos but I don’t know about the Prime. I have searched for the answer but I cant find it.
    iPhone ?
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    16 Amps, so you need a 20 Amp breaker and wiring.
  3. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    12A on the provided EVSE.
  4. Lee Jay
    5,850
    4,036
    Did you try searching in the Charging section of the owner's manual?
  5. bisco
    52,889
    isn't it all 220v in europe?
    jerrymildred and Prodigyplace like this.
  6. Prodigyplace
    12,720
    11,852
    Central Virginia
    I was just going to say they may provide a different EVSE in the UK with the Prius PHV. The Prime is North America only.
  7. bisco
    52,889
    why is he asking about prime in u/k?
    Prodigyplace likes this.
  8. Prodigyplace
    12,720
    11,852
    Central Virginia
    He probably thinks we would not understand the UK models.
  9. bisco
    52,889
    what do you think he has? a pip?
  10. Ferrarilover
    185
    168
    Manchester, UK
    I will have the Prius PHV 2017/18 model in a few weeks and am having a charger installed and just wanted to check to ensure my wiring is good enough.
    16 Amps appears to be the answer for draw so thanks for replying.
    iPhone ?
  11. Prodigyplace
    12,720
    11,852
    Central Virginia
    Outside North America they use the same name for the Gen 3 and Gen 4 based plugins. Prius PHV.
  12. Ferrarilover
    185
    168
    Manchester, UK
    I was trying to help by calling it a Prime for all the folk in the U.S.
    iPhone ?
    bisco and Prodigyplace like this.
  13. Prodigyplace
    12,720
    11,852
    Central Virginia
    No worries.
    Primes come with a 120 volt EVSE. Current draw would be different.
    Does your PHV come with an EVSE or must you purchase one separately?
  14. Ferrarilover
    185
    168
    Manchester, UK
    I have just had a EVSE installed. Paid for by the government and Toyota. IMG_0027.JPG
    iPhone ?
  15. Ferrarilover
    185
    168
    Manchester, UK
    I have just had a EVSE installed. Paid for by the government and Toyota. View attachment 142273
    iPhone ?
  16. bisco
    52,889
    what does your manual say about amperage draw?
  17. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    16 amps just like level 2 here in the states.
    Free home charge unit for Plug-in | News & Events | Toyota UK
    Looks like they get a cable with 1772 plug (car) to type 2 Mennekes plug (Evse) . No Evse built into the cable. EU way of doing things. Wonder if there is much cable theft going on there? Locking latches on both ends?
  18. CharlesH
    2,798
    1,166
    Roseville, CA
    In the EU, public charging stations do not come with a cord and plug. The user is expected to provide their own cord. The charging station just has a receptacle (Mennekes, I believe).
