Maximum EV range
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by plchung, Apr 18, 2012.
  1. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Yeah, being very soft on the pedal and really making use of gaining more speed downhill before an uphill to not have to throttle up a lot makes a huge difference. I've got my range up to 14.7 right now. I want to see if I can make it 15 by the end of April. It's touchy, you do some afternoon drives around here where you simply have to 'drive normal' and it drops but with enough early commutes it keeps going up for me.
    52,855
    some rechargable batteries gain power with break in. is this the case with pip, or do they start off at peak and slowly lose power?
    52,855
    exactly!;)
  4. jim335
    jim335 Member
    100
    50
    pa
    I believe that there will soon be a plug and play battery that will add about 25 miles of range to the prius. It will be modular and removable. It would sit in the cargo area when that space is not needed and removed when the space is needed. It should be able to be charged with the factory charge cable or standard level 2 charger, and not need to be unplugged or charged separately. The charge time would of course be about double because total usable battery would be about double. An upgrade like this would make the prius a far better choice than the volt, from a gas mileage point of view.
  5. mrbigh
    3,686
    699
    Long Island, NY
    ...... your prayers are being listened to ....:rolleyes:
  6. iRun26.2
    iRun26.2 Active Member
    824
    169
    United States
    One things for sure, if you want to get the best gas mileage possible, you (unfortunately) need to PO the drivers behind you.
    I try to be curtious when other drivers are around but I usually do not accelerate as rapidly as most people do.
  7. laskier
    laskier Junior Member
    Salt Lake City
    If this was available, I'd order it TODAY!
  8. bisco
    52,855
    i was thinking about this the other day (wishful thinking) but i'm wondering how feasable it would be to have a removable battery. i think safety is a primary concern and it could be difficult for toyota to create an area in the back that would be crash proof and yet you easily remove and install an extra battery, not to mention user error. it would have to be fool proof for people who can't tell the accellerator pedal from the brake.
  9. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    25 miles battery in the trunk?
    That's about 160 kg (350 lb) to 'plug and play' with...
  10. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Adding 25 miles for a prius would need to have about 6-7kw usable (2.7kw usable yields 11miles). Check out plugin supply's 4kw and 10kw options. Hope you have some serious weight-lifting background. 10kw usable pack is 300 pounds. If you are thinking there will be a variation of the 4kw pack (which is only 100lb for a 11/2.7*4 = 16 miles of EV mode, for a total of 27miles.
    A 4kw system is $5000 (though some stated give discounts0 and you'll still not have the range of a Volt. And it would still drive like a prius. If you only needed 25 miles on some days and 11 was good enough for others it might work, but with the added cost the only advantage would be for those that absolutely hate GM.
