Maximum PSI ?
Discussion in 'Prime Main Forum (2017-2022)' started by Rob43, Sep 12, 2019.
  1. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    OK, good info.
    For those of you ( xray22, m8547, jerrymildred, & mr88cet ) that are at 40 PSI or higher, do you ever get a TPMS dash warning light ?
    Rob43
  2. Trollbait
    12,822
    Not with a Prius, but I've haven't seen that happen in a Camry or Sonic. Though, I might have reset the Camry's TPMS, and the Sonic's manufacture recommended psi was 38.
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Does Prius TPMS warning come on for high pressure? For low pressure, the threshold is something like 25%. So, if it is a factory set, it would warn at or below 27 psi. If the same 25% is what it triggers at higher than the baseline, the factory set TPMS would warn at or above 45 psi. But I think you can reset the TPMS to a new baseline, can't you?
  4. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    Yes, the Prime will trip the dash TPMS warning light for high pressure.
    IIRC the number is 20% higher, so this means a trip range of about ~42 PSI for the rear & ~43.75 PSI for the front.
    Rob43
    Salamander_King likes this.
  5. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    The TPMS does not trip for high pressure, at least at 55 PSI, which I used to have my tires at when I was commuting.
  6. Trollbait
    12,822
    Did you hit the reset button after inflating the tires to that?
  7. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    This is fascinating information, I can't achieve anything over 40 PSI no matter what I do. As soon as my rear tires hit ~42+ PSI I get that dash TPMS warning light.
    Rob43
  8. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    No, I didn't.
    Raytheeagle likes this.
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Nope. I have never bothered resetting the trip point so it's wherever the original owner had it -- or more likely his/her Toyota service center since it was taken there every 10k miles before I got it.
    I'm assuming (maybe some risk there) that it's set at some safe level. It's one of those things that I sometimes think about investigating, but never seem to get to.
    edit to add:
    Also, @Rob43, did you try hitting the reset button to see if maybe that does have an effect? But I'll add that I would not want my rear tires over 40 psi. That's where I drew the line. It's arbitrary, admittedly, but I don't see that there's any gain in going higher.
    #29 jerrymildred, Sep 15, 2019
  10. Trollbait
    12,822
    Seems the law only requires a warning with underinflation.
    Text of H.R. 5164 (106th): Transportation Recall Enhancement, Accountability, and Documentation (TREAD) Act (Passed Congress version) - GovTrack.us
    The Camry SE has a pressure display for the individual tires. It reads high, as much as 5psi, and maxes out at 55psi. That could just be for the display, but it is possible that also applies to the software. Then we can have a Jurassic Park situation where the high pressure warning trigger is never triggered as the system doesn't see values over that max limit, and Jeff Goldblum ends up with a broken leg.
    Prius from Dad likes this.
  11. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    Received this from Amazon today, it seems to work properly. I bought it for an upcoming long trip, I currently have lost faith in my Primes ability to give me trustworthy TPMS information. Currently I'm conditioned to see the dash TPMS warning light go off at or above ~42 PSI hot (starts at 40 PSI cold) in the rear, my concern is that if I'm Losing PSI and get a dash light I'll think it's for a high PSI reading when it's actually not.
    This cheap no-name dash mount TPMS unit will give me exact info on all 4 corners for piece of mind.
    Rob43
  12. Salamander_King
    11,024
    8,978
    New England
    Yap, that's exactly the same TPMS I bought for my winter tire sets without internal TPMS sensors, and now have it on my summer OEM rims with OEM internal sensors. I have checked my tire pressures with manual guages and reading on this external TPMS and found them to match perfectly. Comparing to those values, OBD2 app read internal OEM TPMS sensors reported 0.9-1.4psi higher value.
    Rob43 likes this.
  13. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    ^ Good enough for you, good enough for me !
    I will most likely pull this back off the car once I get back from this trip, and only use it for future trips based on how big and ugly the valve stem TPMS senders are.
    Question: Are you saying that you converted to internal "RF transmission frequency:433.92Mhz" TPMS sensors for your normal DD tires ?
    Rob43
  14. Salamander_King
    11,024
    8,978
    New England
    LOL. I have to agree there. Although, I have started to think it kind looks good on the OEM hubcaps. :LOL:
    "Converted" is not the appropriate term, I don't think. I used elm327 obd2 adapter and app called Tire Assistant to read the data that was being sent by the internal TPMS sensors to ECU. You can do the same thing with Techstream, or with ScanGauge with X-gauge command. With X-gauge, you can see the live info while you are driving but with Trie Assistant or Techstream, the car must be parked in order to read the data. Or if you mean I did something to the external TPMS reader to "catch" the internal sensor signals, then no that is not what I did. I just have them on my OEM tires and rims which has OEM TPMS sensors inside independently of the external sensors just like you are doing.
    BTW, What is "DD tire"?
    #34 Salamander_King, Sep 16, 2019
  15. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    OK got it, I understand now.
    DD = Daily Driver.
    Rob43
    PS, Switch over to my suggested tire in my performance tire thread in your 195 size, you'll send a beer when you do...
  16. Salamander_King
    11,024
    8,978
    New England
    Yeah, Yoko Avid GT is on my shortlist for next set of tires. Though I am not sure of using different tire size as you suggested. My OEM Dunlop has been holding it's tread better than the first year. I still have 5-6/32 left on them. Since I will be switching to snows in a few months, I will wait till next year for the decision on new tires. Do you have any experience with Riken tires that TireTrack rates very high?
  17. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    You must have missed this:
    "PS, Switch over to my suggested tire in my performance tire thread in your 195 size, you'll send a beer when you do..."
    Even if I disliked you,... I still wouldn't recommend that particular Riken tire. That is an AVOID at all costs purchase.
    Rob43
    #37 Rob43, Sep 16, 2019
  18. Salamander_King
    11,024
    8,978
    New England
    You mean the Riken tires? It shows up on Tire Track recommendation at or near the top for most of my preferences. Since winter use is not needed for this set, my priorities are more on comfort and price. For those categories, it is rated better than Yoko Avid GT. I did some research on the brand, it is made by Michellin. The brand was used to be held by a Japanese tire company before taken over by Michellin.
  19. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    Put a side by side screen of the "Full Test Report" (Test Result Charts) for both tires, when you look at their testing data the Riken Raptor HR does VERY POORLY.
    I like you...don't purchase that tire.
    Rob43
  20. Salamander_King
    11,024
    8,978
    New England
    Humm, really? I have no first-hand experience with this brand. But the price and high consumer reviews on this bargain tire were enticing. I was also considering Hancook Kinegy but dismissed them after seeing low scores on consumer reviews. For example, the Riken was rated far better than very popular tire amoung PRIUS drivers, Bridgestone Ecopia 422 Plus on all categories (since there is no fuel economy category in TireTrack review). I did not have very good experience with the Ecopia 422 Plus on my Gen3, so I thought the reviews are generally credible.
    #40 Salamander_King, Sep 16, 2019
