May have reached 200k
Discussion in 'Prime Main Forum (2017-2022)' started by Marine Ray, Apr 1, 2022.
  1. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Just because you can, doesn't mean you should. Consider priorities.
    That use of electricity may be unnecessary waste... exactly what Toyota is striving to avoid.
    Remember, the battery can be warmed simply by using it, rather than run warming equipment.
  2. Trollbait
    12,827
    This is harsher language than what Toyota uses with their other plug ins.
    Have you turned off the your Prime's battery warming system to conserve energy?
  3. john1701a
    12,840
    5,312
    58
    What's wrong with clarity? Notice how much FUD comes about from ambiguity.
    There's a huge difference in energy between 10°C for ordinary EV operation and 50°C needed for DC fast-charging.
  4. hill
    9,038
    Yeah, there's no ambiguity with stating your car's charging is crippled if it's freezing outside. And as for the 'doubt' in FUD? No doubt - many who seek to go electric will buy elsewhere if battery chemistry won't allow charging in freezing weather ... at least in states that suffer these weather conditions. Fair weather EV? One may suppose that kind of dynamic will work ok in most of California - where most USA sales will occur. Whole countries like Denmark, Iceland, Norway? Not so much.
    #84 hill, May 10, 2022
  5. john1701a
    12,840
    5,312
    58
    For those doing research, you will discover that -4°F (-20°F) is the threshold for LFP chemistry. You will then notice that slower charging speed we have been told about matches the rate limit of 1C for LFP. Taking a look at the supplier, you will see that CATL is a provider of LFP cells for several other automakers. More and more, it looks like the AWD model of bZ4X in the US will be the first model of Toyota to implement LFP.
  6. Trollbait
    12,827
    The PiP didn't need a battery warmer for ordinary EV operation. Why does the Prius Prime? If the PP does need it, why would a BEV not need to use fast DC charging in cold weather?
    Except it isn't looking like that.
    The bZ4X XLE FWD has a curb weight of 4266 pounds. AWD brings that up to 4332. LFP has benefits, but energy density and specific energy is not among them. CATL's LFP have an energy density of 160Wh/kg, and typical nickel based Li-ion is around 260Wh/kg. For the AWD pack to be made of LFP cells, the weight would increase by over 300 pounds. Using CATL's cell to pack technology, the weight difference might get down 250, 200 pounds.
    Perhaps Toyota and Panasonic did a poor job of packing the FWD packing, which does not seem likely. The FWD battery doesn't have the warnings about cold and charging, so its battery likely isn't LFP.
    Removing pack casing structure would seem to be the only way to keep the weight difference low. A LFP pack might even need the extra space from removing internal bits. It would be about 4 gallons of steel though.
    But if that is the case, why be secretive about the battery chemistry used? Why let uncertainty from negative footnotes spread? Being open about limitations is negated when the reasons aren't shared. LFP is cars is not new. There are drawbacks, but those come with benefits. Toyota not being open about the AWD pack being LFP, if it is, while letting the drawbacks without the benefits come out, will lead to FUD over Li-ion batteries.
    hill likes this.
  7. prius16
    prius16 Active Member
    462
    246
    New England
    2022 Prius Prime
    Quick answer:
    The Gen3 used the heavier, and less cold temperature sensitive NiMH batteries.
    The Gen4 uses the lighter LiON batteries. That helps to get much more EV range, and to allow the car to stay in EV mode up to ?~70mph?.
    The Gen4 Prius AWD also uses the older and heavier NiMH batteries. That car will likely be used in colder climates. The cheaper NiMH batteries also help to keep the overall cost lower.
    #87 prius16, May 12, 2022
  8. PaulDM
    PaulDM Active Member
    616
    320
    UK
    2022 Prius
    Excel
    In US correct. In Europe Prius HEV and AWe both still use NiMH. Only the PHEV uses LiON.
  9. Trollbait
    12,827
    The PiP, Prius Plug In, that preceded the Prius Prime, used Li-ion.
    I am unaware of any recent plug in that used NiMH. The patents preventing that expired years ago now. It looks like BASF didn't unlock the potential they saw in NiMH, or Li-ion simply came down in price to the point it wasn't worth it.
  10. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
  11. Trollbait
    12,827
    I just got a notice about a correction to SS holdings for the 2020 tax year. I wouldn't bet on an overworked IRS keeping a website immediately up to date.
    Merkey likes this.
