Maybe a new $10/bbl oil tax
Discussion in 'Environmental Discussion' started by austingreen, Feb 5, 2016.
  1. austingreen
    austingreen Senior Member
    13,675
    4,213
    Austin, TX, USA
    You forgot all that fuel oil (diesel, home heating, etc) and other petroleum products? here or the yields.
    U.S. Refinery Yield
    That's 45% or 18.9 gallons of gasoline + 32.6% fuel oils or 13.7 gallons (diesel has more energy than gasoline so perhaps refiners will add a little more of the tax here) plus other things that can be partially taxed. Lets just take the 32.6 gallons of liquid fuel and tax it equally for the $10 (again gas would be charged a little less in real life) then we get 30.6 cents a gallon, but there are only 0.9 of a gallon of gasoline in a gallon of E10, that makes it 27.6 cents. Why did I say a quarter, or 25 cents. Well I think more would be taxed from the diesel and some from the other components, making it around 25 cents. I really don't know if it will be 20 cents or 31 cents, so I estimated a nice round number. Certainly diesel and home heating oil will get some of the tax, those are prime products. Put the tax high enough and they will crack some of the other components and get a higher yield of liquid fuels.
    51,950
    doesn't europe manage to not tax heating oil?
  3. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    I think they do tax everything in EU just some things harder than others.
    Yes if we spread tax out to different products it could be less, but I was curious to know if it was just gaso tax how much it would be equal to,
  4. austingreen
    13,675
    4,213
    Austin, TX, USA
    To raise the same amount of revenue yes they would need a higher gasoline only tax.
    If you are going reduce dependance on foreign oil then a tax on oil (the thing you want to reduce demand on) then some thought about a $40/bbl tax would add about $1 to gasoline, and $1.20 to a gallon of diesel, but no one knows how the refiners will distribute the tax, and how they would change their product mix. I simply divided by 4 and think this tax will add about $0.25/gallon of gasoline. It definitely could be as high as $0.35/gallon or as little as $0.20/gallon depending on how the refiners allocate the tax.
    http://www.economist.com/blogs/freeexchange/2015/07/reducing-carbon-emissions
