Maybe a silly question but.......................
Discussion in 'Gen 2 Prius Main Forum' started by Jeddy, Apr 24, 2009.
  1. Jeddy
    Jeddy Wild and Wooley
    West Coast
    but I take it the Prius does not need to be smogged at all?
  2. effwitt
    effwitt Paparazzi Magnet
    225
    Eagan, MN
    What do you mean by "smogged"?
  3. rcsting
    rcsting Toyota Fanatic
    282
    111
    Gold River , California
    Your location shows "West Coast" If you are in California you are exempt from smog testing.
    Smog Information
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    At first I thought the OP said "snogged". I thought "Here we go. Another sheep thread."
    Tom
  5. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    That's right NO SMOG Test in California!!!!
    That will save a few bucks, and our time....
    Tom, that was Baaahhhooggged
  6. dogfriend
    7,512
    1,188
    Carmichael, CA
  7. Jeddy
    West Coast
    Well I got a little excited until I read 2010. Darn I thought in California we would never be smogged with the Prius. Well I guess California is hard up for every penny.
  8. dogfriend
    7,512
    1,188
    Carmichael, CA
    It is possible that they may postpone implementing testing. Besides the Prius, Camry and Lexus HSD system, they will have to figure out the procedure for the Honda IMA hybrids, the Ford Hybrids and the GM mild and two mode hybrids. I could see this taking another decade or so at the rate the state moves on anything. :madgrin:
  9. Patrick Wong
    18,200
    6,479
    Since Toyota hybrids can enter Inspection Mode, what is the big deal about smog testing? Is the CA BAR concerned that it is not feasible to use dynamometer testing since Toyota does not recommend driving the vehicle in Inspection Mode?
    Should that be the case, it would still be possible to test the vehicles like in the "old days", where emissions are tested at idle speed and at 2,500 RPM with the shift selector in P...
  10. dogfriend
    7,512
    1,188
    Carmichael, CA
    Hi Patrick,
    I have a Ford Explorer that can't be tested on the dyno, and they do test it the "old way", but I'm always worried that the smog tech will accidentally try to test it on the dyno anyway.
    I would speculate that the big deal would be the modification of the software that they use at all of the stations to test and send the results directly to DMV. They will need to accommodate the Toyota hybrids and the other hybrids as well. I hope they don't require dyno testing for the Prius, or I will then have to worry about the smog tech damaging the Prius every other year as well.
  11. hill
    8,278
    2010 is the soonest for CA. Fortunatly, our Prius' are not smug tested ... in that regard, they really spew.
    :D
  12. Huntceet
    Huntceet Junior Member
    85
    Chicago area
    2018 Prius
    With the advent of OBDII in 1995 or so there was really no reason for dyno or even just tailpipe testing. Any malfunction of the emission system sets a code and it can be read at the testing station. Any other testing is just political boondoggling IMHO.
    Rod
  13. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    Arizona does in fact only do OBD II diagnostics on 1996+ cars. 1995 and earlier still get the dynamometer test.
  14. zonie911
    zonie911 Member
    585
    Nashville, Tennessee
    It may apply in that manner in Tennessee, also, I only know that I have to be "smogged".
    Oh, well, I guess I'll find out.
    :smokin:
  15. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    Anyway, I'm not in favor of an exemption for the Prius -- it does have a gas engine that can malfunction and spew pollution. People will drive around forever with the "check engine" light on if you let them.
  16. Patrick Wong
    18,200
    6,479
    Hi Rod,
    This might be true if the emissions control hardware is left undisturbed. However it is possible for an unscrupulous owner to bypass a sensor in order to make the engine ECU think that malfunctioning hardware is in fact operative. I think it is in the public interest (assuming the public cares about clean air) to have periodic inspections, including visual inspection of the hardware, and while the car is there see what emissions come out of the tailpipe.
