Mazda 6 diesel. Sign me up.
Discussion in 'Diesels' started by massparanoia, Mar 22, 2013.
  1. massparanoia
    massparanoia Active Member
    697
    467
    Virginia
    It's coming here, Mazda has videos about the diesel on the US website. I would post the link but I can only access the mobile site now.
    ewxlt66 likes this.
  2. El Dobro
    El Dobro A Member
    7,103
    3,282
  3. massparanoia
    697
    467
    Virginia
    No vids on the mobile site as far as I can tell. I couldn't find a link to switch to the desktop site.
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The extra $0.30 - $0.45 cents per gallon for diesel vs. regular unleaded makes this a tough sell in my area unless you just like diesels. So subtract a few mpg or more from the EPA score to compensate for higher fuel prices.
  5. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    it should be coming later in 2013... it is a good engine, Euro VI if I remember correctly... good mix of power and mpg. some small issues to start with which should be fixed by now.
    it gets about the same mpg as 2.0 TDI but with EuroVI and little bit more power... so that should be few mpg more over 2.0 TDI in USA.
  6. massparanoia
    697
    467
    Virginia
    Yeah you're right. The Kammback has produced such styling masterpieces as the AMC Gremlin, Pontiac Aztec, Citroen CX and the Lancia Y10.
  7. 4EVsHybrids
    4EVsHybrids Junior Member
    43
    Why on earth are we wasting our time with Diesels? Clean Diesels are an oxymoron as the World Health Organization has stated time and time again. Pushing Clean Diesels is the same as saying Cigarettes don't cause lung cancer? They both do! Diesel Technology is a joke and should go the way of the Dinosaurs, extinct already!
  8. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Mazda has said they'd be bringing a 6 diesel sedan but no promise on the wagon os it's doubtful. The US diesel wagon with a stick remains a VW-only phenomenon.
  9. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    This is a midsize sedan, why are you comparing it to a Prius? Midsize sedans are one of the best selling segments so it seems like a lot of people have old-style preferences for looks.
    I usually use a block heater which makes starting easy, but here's one time where it was cold (-8F) and I didn't get to plug it in.
  10. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Sounds like you should sit in a Prius sometime.
    Absolutely.
  11. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    I have, it is not a midsize sedan. Interior volume puts it in the midsize class mostly because of the high roof but useful measurements such as headroom, legroom, shoulder room, hip room, are more in line with a compact than a midsize.
  12. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    While you need more shoulder and hip room to occasionally put 3 across the back seat, it is the leg room that really matters. Prius L also has more front, rear legroom and headroom than my '12 Acura tsx. And against a Mercedes E-Class?
    2013 Toyota Prius vs. 2013 Mercedes-Benz E-Class
    2013 Prius/2013 M-Benz E-400h
    Front legroom 42.5 "/41.3 "
    Rear legroom 36.0 "/35.8 "
    Front headroom 38.6 "/37.9 "
    Rear headroom 37.6 "/38.2 "
    Front hiproom 52.7 "/N/A
    Rear hiproom 51.2 "/N/A
    Front shoulder room 54.9 "/57.8 "
    Rear shoulder room 53.1 "/56.9 "
    Luggage volume 21.6 cu.ft./15.9 cu.ft. Compare Side-by-Side
  13. spwolf
    3,156
    440
    Eastern Europe
    Prius doesnt have high roof hence rear headroom isnt that good, so thats not why interior volume is so good... it is because its wheelbase is considerably larger than Corolla's, its one size larger (same as Euro Avensis)... thats why rear legroom is so impressive.
  14. Sergiospl
    3,938
    1,351
    28
    ^^ 106.3 Prius wheelbase vs 106.5 for Acura tsx.
  15. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    Either way the Prius is not comparable to most midsize sedans for space.
    massparanoia likes this.
  16. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
  17. mcalifornia
    mcalifornia New Member
    Prius v gets the same 57mpg on the NEDC cycle.
  18. Trollbait
    12,818
    The big study that linked cancer to diesel exhaust from the WHO was with miners and their off road diesel equipment with no emission treatment systems. Gasoline engines under such conditions would be just as unhealthy if not out right deadly.
    The only reason gasoline exhaust is clean now is because of 30+ years of research and development. Even then, a new diesel is cleaner in some measurements to a new gasoline car.
    wxman likes this.
  19. ETC(SS)
    7,530
    I used to be a fan of Mazda....and in fact I still admire the brand but this car has two tragic flaws;
    1. The big goofy "always glad to see you" guppy grin. - although this car's Cheshire cat grill is somewhat subdued, and the car looks really good on a 'puter screen!
    2. Diesel. Booooo. Expensive.....and built to stay that way.
    No thanks.If diesel was 50 cents cheaper, and if they cost the same as a gas burner, and if they were as cheap to work on.....I might consider getting one...but then if my aunt had a set of ba....(*!*) er....if she had a mustache, then she'd be my uncle. :D
  20. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
