"Mazda building a Volt of its own"
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by TimBikes, Aug 28, 2008.
  1. dogfriend
    7,512
    1,185
    Carmichael, CA
    I think this is true, although the article stated that they were planning to use a 1.4L. The advantages that I can think of for using the rotary: small size and low weight compared to a conventional piston engine with the same output, low vibration, simplicity. In fact, the complete gen set (engine + generator) could be very simple and compact. The generator would be the starter and generator similar to the Prius. And it would only need to operate at one speed, so both the engine and generator could be optimized.
  2. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Maybe Mazda will use the Rotary Atkinson Engine. That would be cool.
  3. etyler88
    etyler88 etyler88
    450
    Dover, DE
    I could get 30 mpg with my 79 RX-7 when I wanted to.
  4. allemandeL3ft
    allemandeL3ft New Member
    Tacoma, WA
    I'm a big mpv fan; it's my current car. Maybe this will mean that they'll reintroduce it to the NA market. More likely this will be JDM only. Like many of their tastiest morsels.
  5. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Even if it turns out to be vaporware, nothing wrong with prodding Toyota and others to step up EV development. I hope Mazda does produce this vehicle
  6. daniel
    14,487
    1,518
    Spokane, WA
    While the Prius can use engine braking the same as a conventional car, an EV or a series PHEV cannot. However, there are alternatives:
    A large resistive heat dissipator could absorb and dissipate the energy from re-gen braking after the battery is full. Using air or liquid cooling would allow a big resistor to take the energy of slowing the car.
  7. dwreed3rd
    dwreed3rd New Member
    742
    Marietta, Ga
    How about one of those steel-plate soled motorcycle racing racing boots to wear on the door-side foot? :rolleyes:
