Featured Mazda on meeting emissions
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Aug 12, 2017.
  1. bwilson4web
    16,523
    Source: http://www.autonews.com/article/20170801/OEM02/170809957/&template=print
    Davis, senior vice president in charge of special assignments for North America, remains critical of the way the industry has introduced EVs for emission compliance purposes.
    “Take the $7,500 EV credit off the table? At the same time, you take the EV mandate off the table,” Davis said dismissively. “Let the government keep the $7,500 and let the industry find the best way to meet the clean air standard. Make it CO2, make it grams per mile, fuel economy — whatever feels best.
    “But don’t mandate the particular powertrain.”
    Mazda has been on the sidelines as competitors brought electric models to market. But Mazda is a relatively small global automaker, without the resources to develop a wide range of powertrains.
    Mazda has made fuel efficiency a priority with its Skyactiv technologies. But it is focusing on internal combustion engines, including upcoming diesel options
    I would be more impressed if we were reading about Mazda engines having 40% thermodynamic efficiency. One of the things electrification does is keep the ICE in peak efficiency modes and otherwise off. Mazda has no such option.
    I first hear Davis on the video interview between minutes 6:14-7:55 at: AD #2166 – Secondary Loop A/C System, Continental’s Wild Wheel & Brake Combo, Hot Stamping Gets Cold Shoulder – Autoline Daily
    Davis thinks electrification is just relocating emissions with no understanding that it is also the ultimate flex-fuel from coal, natural gas, wind, hydro, nuclear, e.t.c. He also seems oblivious to how it can compliment an ICE so the total vehicle efficiency and range are improved.
    Zythryn likes this.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I agree. But - he could have a point with not totally closing the door. Fuel economy and emissions have both improved dramatically in the last 10 years. Figures for Mazda 3 2.0l Auto here are:
    2004 212 CO2 (8.9 l/100km;
    2010 193 CO2 (8.2 l/100km);
    2014 (current) 136 CO2 (5.8 l/100km).
    That's not much of an improvement 2004 -> 2010, but quite substantial to 2017. They started well behind a 2004 PRIUS - it'll be interesting to see whether their compression ignition Mazda 3 in 2 years is as big an improvement as they predict.
    Mazda have their i-Eloop brake regeneration - which is only a small fraction of what a PRIUS and other Hybrids regenerate - but I'd be surprised if they're not working on increasing the capacity. I understand it uses capacitors rather than a battery, and only helps with ancillaries rather than a traction motor - so far. With TOYOTA buying more of MAZDA last week, maybe there could be more plans?
    I suppose time will tell.
    austingreen and bwilson4web like this.
    52,818
    sour grapes. if he got what he wanted, then he'd be pushing for lower standards when they couldn't meet them.
    if you can't build a hybrid or electric car, your engineers should be fired. if you don't want to... ahh, there's the rub.
    Trollbait likes this.
  4. Trollbait
    12,818
    Davis also ignores the fact that the federal government had additional goals with the federal incentives for plug ins.
  5. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    Actually ... mazda should be easily beating the 40% peak engine efficiency with its release in 2019 of a spark controlled compression ignition gasoline engine. Only question is how reliable and expensive will it be. Nissan and GM have been working hard on this technology also. Mazda appears to have tamed the beast, at least in preproduction form, by using using lots of sensors and fast microprocessors to control supercharging, valve timing, and amount of cooled egr. skyactiv-x is the name. When in HCCI mode, NOx should be lower than conventional engines before the cat. Peak compression when including the supercharging is 18:1. My guess from what I read is HCCI will be low load, either lean or with lots of cooled exhaust gas, and lots of efficiency because of the 18:1 guesstimated compression and no flame front. Replace the super charger with a turbo (maybe a hybrid electrical super/turbo instead of the mechanical supercharger mazda looks like its using) and you could get thermal efficiencies over 50% in a 180 hp - 2L engine at low loads. For startup the speculation is valve timing (hot exhaust gasses kept in the cyclinder) and spark ignition to quickly and efficiently get the engine up to temperature. For heavier loads or high rpm it appears that the engine will run the miller cycle with late intake valve closing and use less exhaust gas, and stoich or slightly rich mixtures. My guess some of the sensor and processing advances are what finally will let this technology work in cars at a large variance of altitude and outside temperature.
    I doubt dave thinks this, but mazda is behind, and have partnered with toyota on electrification which is also behind. If you don't have a drill, you may argue that you don't need one. Still I find this mazda dishonesty not too bad, they are not like some other, ahem, car companies, that actively lobby and press release against electrification.
    Hell you design a mazda 6 or cx-5 with such a 2L skyactiv-x and 10 kwh of batteries and you probably get decent electrical range and one of the highest mpg vehicles in its class on the highway. I think that is probably not until at least 2022 though.
  6. bisco
    52,818
    i would want a 10/150 warranty on that engine, until it's proven itself.
  7. Zythryn
    Zythryn Senior Member
    6,411
    4,412
    I do agree that the government should incentivize the goal, not the specific drivetrain.
    However, I would also like to see the government stop incentivizing the century old oil drilling technologies ;)
  8. bwilson4web
    16,523
    I appreciate your optimism but I know the Carnot formula and the temperature values are in Kelvin. The only engines I know of that meet that kind of thermodynamic efficiency have after-exhaust, secondary systems to extract the last of the heat. I am happy to be proven wrong but I find it improbably in a Mazda-sized, car would achieve 50% thermodynamic efficiency.
    telmo744 likes this.
  9. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Besides being the ultimate flex fuel...he misses the point that "just relocating emissions" by itself can be a good thing. Has he not seen the major smog problems in many cities around the world? And even if a car's emissions can be made very low, at some cost, isn't it going to be cheaper and better when being done on a large scale at a power plant, rather than hauling around the equipment to do this?
    (Of course the counter argument is that a big battery is just this)
    Mike
  10. bisco
    52,818
    he's not missing the point, he's intentionally spreading fun. mazda can't compete, and they're worried.
    these are the words of a man who's ship is sinking, and he's searching for a lifeboat.
    pilotgrrl likes this.
  11. Zythryn
    6,411
    4,412
    He would do better if he actually was looking for a lifeboat.
    Seems to me he is spending his time and efforts in punching holes in other people's lifeboats:eek:
  12. hill
    9,023
    fun as in, "ZOOM ZOOM ZOOOM" ? ... or as in fud ...... this has been a gramar nazi presentation
    :D
    pilotgrrl, 3PriusMike and bisco like this.
  13. bisco
    52,818
    yeah, i know. and of course, no edit button.
  14. hill
    9,023
  15. bisco
    52,818
    i loved my miata, but can you say 'boutique' car maker? or as some anti ev-ites would say, _______ cars.
  16. hill
    9,023
    In the 1970's there was a wait list for the Mazda RX7 with its wankel rotary ICE. Powerful - fun, & easy on the eyes but very dirty & unreliable. Still - everybody wanted a ride. Hmm - suddenly I'm remembering an old girlfriend.
    #16 hill, Aug 16, 2017
  17. mikefocke
    4,073
    1,858
    Sanford, NC
    I recall losing money on Toyo Kogyo stock. During the Wankel craze.
  18. austingreen
    13,714
    4,232
    Austin, TX, USA
    Yes to break 50% it would need a turbocharger and intercooler, and the first skyactiv-x will have mechanical superchargers, so it can not extract extra power from the exhaust stream. A twin charger (super/turbo) or an electrical turbo charger could easily break the barrier in HCCI mode. That would add to cost though, and we don't know how much the additional sensors, supercharger, intercooler, strength to withstand the 18:1 compression and expansion, and processing power add to the standard skyactiv gasoline engines of today.
    Mazda has stated that their prototype is 20%-30% more efficient than their current gasoline engine which is already very efficient.
    Compare Side-by-Side
    Let's say it replaces the 2L in the mazda 3 and is 20% more efficient (25% on city cycle, 15% on hwy cycle that uses more high load in the test) we get a car that will be 35 mpg city/ 43 mpg hwy and probably bests a toyota hsd that has the same cdA and rolling resistance with a cruise control on long highway trips. That is much more than 40% peak efficiency, but worse than a hsd on epa tests. Add it to an hsd which mazda appears to be licensing from toyota, and you get a even better result.
    Again, I'm looking foward to seeing how well this engine does, and if in a phev with electrical turbo charging, if it can get steller long trip mpg, to go with the all electric short trip and city trips.
  19. austingreen
    13,714
    4,232
    Austin, TX, USA
    I don't remember a wankel craze, I may be too young. I remember the cars. The key with a wankel is low weight and volume to power. A liquid cooled, normally aspirated or lightly blown, 4 stroke is bigger and heavier for the same power, but has always been more efficient. IIRC a similarly powered wankel is less expensive to build as well.
    Today with modern safety requirements, cars are heavy, and saving weight with a wankel at the expensive of efficiency is not a good tradeoff in a car. This new mazda engine is hyper efficient, but more expensive, and I'm guessing heavier, than a similar 4 cylinder engine. I also given the ballance of the company, would not consider mazda a great investment.
  20. Trollbait
    12,818
    It's long odds, but a Wankel might be a good choice as a range extender on a plug in, because of the smaller size and lower weight. Efficiency will be comparatively poor, but when 90% or more of the annual miles are grid powered, it could be an acceptable trade off.
