MDF vs hand cal variance with top offs vs fill ups.
Discussion in 'Newbie Forum' started by NinnJinn, Feb 22, 2012.
  1. NinnJinn
    NinnJinn Member
    276
    Indiana
    I have driven my Prius over 1500 miles in the last 2 weeks. I have noticed that if I top off my tank, (3 pips or more left) hand cal vs MFD is about 1.5-2mpg off. Yet there has been twice my car "dings" and the last pip is flashing. When this happens, I find that MFD vs hand cal is always 5+mpg difference.
    Just curious if this happens to anyone else?
  2. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Try to resist the tempatation to top off the tank. With a bladder system you risk overfilling and either:
    A: Cause the bladder to over-expand then retract and push fuel back out which results in you standing in a puddle while gas spills out of the filler neck for 5-10 minutes.
    B: You overflow into the emission system components and cause expensive damage.
  3. NinnJinn
    NinnJinn Member
    276
    Indiana
    So basically I need to just wait until I'm down to the last pip then? I always have this fear I am going to run out of fuel. The least amount of fuel I have put in was 4gals. 2 were over 8gals, a 7 gal and a 6. Except for 1 they have all had at least 250 miles since last fill up.
  4. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I would never make such a suggestion because each situation is unique and only you can determine when you should fill up. I fill at 1-2 pips usually but I generally get 360-500miles to a tank. Filling up every 250 miles kinds sucks but I think running out of fuel would suck worse..... Unless a bus full of Hawaiian Tropic girls stopped to help you.
  5. Mendel Leisk
    38,763
    There's no reason to stretch a tank, except for (dubious) bragging rights.
    I fill up anytime we're near our usual station and the tank is less than half. I fill till it does the auto shut off, and don't try for any more.
    As far as calculated vs displayed mileage, our displayed mileage is consistantly optimistic by about 7%. I use it as a rough gauge as the tank progresses, but rely on calculated.
