Measured effect of engine block heater on my MPG
Discussion in 'Gen 3 Prius Fuel Economy' started by mite66, Dec 17, 2010.
  1. mite66
    mite66 Junior Member
    36
    I've been logging all my MPGs in the last couple of weeks for my daily commute to work. I must say here that it's a very short trip (1.8 miles) and it barely gives the engine enough time to warm up, especially since the temperatures are quite cold these days here.
    But this scenario is perfect to really measure the benefit of the EBH during the 5 first minutes of any trip.
    I'm able to plug my EBH for two hours before my departure to work but don't run it for my way back home so I'm now able to compare my MPG results between those two situations. The temperatures are also often colder in the morning than they are for my way back so we"re allow to think that my morning MPG should normally by worse than my evening ones.
    So here's what I got:
    2 hours EBH: 40mpg
    Average outside temp: 15.3 F
    Without EBH: 35mpg
    Average outside temp: 22.5 F
    I'm sure that the benefit would also be there for longer distances since the coolant is still colder (according to SG II) upon arrival without EBH than it is with it.
    Note: In all cases, I haven't use the heater nor the rear defrost.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Interesting. Can you say that the two legs of the trip have very similar topology and stops?
  3. mite66
    36
    Yes they do, 2 stops and 5 traffic lights in each directions.
  4. Former Member 68813
    3,524
    981
    US
    I totally belive you. My MPH in first mile was never better than 25 and MPG in the first 2 miles was never better than 38. Now it's much lower during winter. Basically, you use electricity rather than gasoline to warm up the engine. The side effect is much lower engine wear because as everyone knows, most wear happens during cold run (start up).
  5. Cpl Bloggins
    Cpl Bloggins New Member
    New Brunswick, Canada
    Could you check your MPG while using defrost on Hi temp setting next week to compare.
    thanks!
  6. fuzzy1
    10,272
    As a check, it would be worthwhile to measure both directions on a day without EBH. Even a very small elevation difference can make a noticeable difference in mpg in the opposing directions.
    2 people like this.
  7. dsljay
    dsljay Junior Member
    Breinigsville, Pa.
    Nice work mite66. Did you calculate how much the two hours of electric costs? Money wise, is the ebh a winner or loser?
    Happy holidays, Jay
  8. stpool
    stpool New Member
    marion nc
    If he is at 10 c a kWh and the heater is 400 w for 2 hr that would be 8 cent. If he drove 5 days a week would be less than 50 cents a week
  9. mite66
    36
    Thanks Jay,
    the answer is... nop
    In my case, the EBH cost more to operate than the very small amount of fuel that I save by using it. I do think that for longer runs, it would indeed make sense moneywise. althougth I doubt that the money saved will also compensate for the cost of the EBH itself. But anyway, we're talking pennies here and we all bought Priuses for one reason, and that's not to save money on fuel isn't it ? (unless you're a taxi driver and drive it 40,000 miles or more per year)
    By the way, I finally broke the 60mpg barrier this morning, that's my best result since I own the car (4 weeks). But then, I was cheating (using too much battery) and the very low car density helped me to avoid all the red lights :).
    And finally, Santa should bring me my Enginer 4kwh plug-in kit today :D. I'll probably be able to install it sometime next week and I'll post the results as soon as I get something.
    Merry Christmas to you all !!!
  10. Mendel Leisk
    38,955
    I worked out the cost per hour for a 400 watt block heater (for our previous HCHII) before: in our area it was under 10 cents per hour. Is the Prius BH about the same?
  11. rebenson
    rebenson Member
    364
    43
    Suburb of Chicago
    Thanks for the information. I guess I need to look into adding this option... sounds like it would be well worth the investment.
  12. markabele
    5,084
    1,782
    Nebraska
    Want to bring this thread back from the dead and start a new discussion about any sort of cost effectiveness of using an EBH.
