Mechanical key replacement- cheapest way?
Discussion in 'Gen 3 Prius Main Forum' started by wstt, May 14, 2018.
Tags:
  1. wstt
    wstt Member
    148
    26
    Does anyone know the cheapest way to replace the mechanical key that slides into the fob? It is a laser cut key. I still have the other and I also have the key code that came with the keys and I think they can also use the VIN to get one made.
  2. kingman
    kingman New Member
    22
    kingman az
    buy the blank on e-bay and have a locksmith cut it for you
  3. wstt
    wstt Member
    148
    26
    Can a locksmith do a laser cut key? I thought the laser cuts were best done by a machine recreating the code, and not tracing another key.
  4. gifuboiler
    gifuboiler Junior Member
    SF Bay Area
    Laser cut is a misnomer. Any locksmith can copy the key. I bought a blank on ebay and had it copied at a kiosk in the mall.
    Raytheeagle likes this.
  5. xDe3JaYx
    xDe3JaYx New Member
    WA
    Search for "FREE PRE-CUT EMERGENCY KEY for LEXUS and TOYOTA TRUNK or DOOR KEYS" on eBay. You just have to take some pictures of your key and they will send you a cut key.
  6. ChapmanF
    19,058
    Well, it has to be a locksmith with the side-milling machine ... maybe 'most all of them have it now. It isn't cut with lasers ... "LASER" is the trade name of that line of machines. It uses a spinning cutter bit.
    Entertaining to watch one in action. It can copy a key, but it isn't just a mechanical follower flopping over the old key while it cuts the new one, like the things that used to be in every hardware store. It's computerized, of course, and it sends the milling head out with a probe attachment and traces out the whole old key, then retracts, grabs a cutter bit, and mills out the new one.
    -Chap
  7. tonycd
    tonycd Member
    84
    56
    Thanks, Chap. Very informative.
  8. Phil Watts
    Phil Watts New Member
    I wound up finding a locksmith on eBay that offers a mail service: you mail his shop a blank and either a photo of the key or the key code (obtained from a stamp on the actually door lock mechanism) and he'll cut a copy. Free return shipping, total came to $25.
    I will circle back to let everyone know the quality of the cut key.
    As for the key fob, I purchased an OEM used one off eBay and programmed it using Techstream no problem.
    CR94 likes this.
  9. CR94
    CR94 Senior Member
    2,839
    1,245
    Northwestern S.C.
    Do you have to take the door apart to read that stamp? When I bought my car used, "Certified" from a dealer, they told me they didn't have the original key code because the previous owner lost it. I thought the dealer should have that code on file.
    How could a blank from eBay have been "used"?
  10. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    Please do and the eBay link.
  11. Adam Foldi
    Adam Foldi Junior Member
    Providence, RI
    Just want to come back to this after many years and say thank you! I did that exact search, and found a good company. I followed the instruction on the listing and sent 3 photos of my key. I can follow up to report back on how they did. Very excited to only spend 22$. I already bough a key fob off ebay and programmed it myself with techstream.
    Ebay link for key cutting: REMOTE FOB EMERGENCY KEY (BLADE CUT FREE by PHOTO) for 2005 - 2021 Lexus &Toyota | eBay
    For key fob
