Mechanics: what are your most common tools?
Discussion in 'Gen 3 Prius Technical Discussion' started by PixelRogue, Sep 3, 2016.
Tags:
  1. ChapmanF
    19,009
    Those must be as common as seals in SK.
  2. vvillovv
    vvillovv Senior Member
    4,337
    1,518
    NY
    flashlight or headlight
    I haven't gotten to the point where I can finish to many jobs with my eyes closed.:cool:
    kenoarto likes this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Ill be honest Mendel i have never used the impacta part. I had heard good things but not used it. But there still the worlds best Phillips screwdrivers.
  4. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    10mm socket for the win.
  5. Mendel Leisk
    42,330
    Not sure if I’ve posted this before; short video on installing a Riv-Nut in tight place, where the official tool couldn’t fit:
  6. skorpyo33
    skorpyo33 Junior Member
    30
    Sebastian, FL.
    And spark plugs in my 3rd gen.
  7. PixelRogue
    489
    86
    US
    This has been a great discussion!
    If you had to pair that down to an emergency kit to fit in some hidden cavity in the Prius (now the later model Priuses) what tools would you keep handy?
  8. sfprankster
    sfprankster Active Member
    444
    490
    Santa Cruz Mountains, CA
    A credit card :p
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    In the car, I keep a socket & 1/2" drive breaker bar for lug nuts, a tire plug kit, an adjustable wrench, Phillips & straight screwdrivers, needle nosed and adjustable pliers. That's in a tool bag in the EVSE cable storage area. And I have my Leatherman tool in the armrest console up front.
  10. ChapmanF
    19,009
    I looked at a Gen 4 one day at the dealer and walked away shaking my head because its hidden cavities are so skimpy compared to Gen 3, I couldn't imagine getting my customary complement of tools in it anywhere.
    jerrymildred likes this.
  11. PixelRogue
    489
    86
    US
    I have been noticing the reduction with each new model.... my latest change was from the 2010 Gen 3 to 2012 PIP and lost a good chunk of the trunk, lost spare tire, extra hidden spaces...and the current gen smaller still.
  12. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    I carry some fluids, a flashlight, drinking water, air compressor, battery booster, lugnut cross wrench, cell phone with a OBD2 adapter, and a small multi-tool.
    Things are so complex on newer cars that it's futile to carry around 50+ pounds of tools "just in case" when it's highly likely that I can't do anything outside my shop anyway.
  13. Toffer
    Toffer Junior Member
    My 2010 Prius calls for a #10 twelve point socket for the removal of the connecting rod bolts since I am changing out the pistons and adding new piston rings. A 6 point metric socket will not fit. The main bearing caps also calls for a 12 point metric socket
  14. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    In the car, I keep a battery jumper, tire plug kit, air compressor and first aid kit.
    Raytheeagle likes this.
  15. Mendel Leisk
    42,330
    A few more in-car items to consider, not mentioned directly above:
    reflective vest
    Gloves
    Flashlight
    Signal cone or triangle
    Heavy/bendable wire (twist tie purpose)
    Tape
  16. AW82
    AW82 Member
    188
    99
    Madison, WI
    I would edit slightly: 10mm DEEP socket. 1/4 drive.
    I can do a crazy amount of work with just that (plus the ratchet, obviously) on my Honda and Toyota. In fact, it's the first thing I pick up even if it's a new-to-me job. 90% of the time, it's the right tool. Sometimes I need an extension or two...
    I used to have a Canadian-made Pontiac. Not only was every nut and bolt a different size, sometimes the nut would be SAE and the bolt head would be metric :cautious:
  17. Mendel Leisk
    42,330
    Acquired a Porter Cable impact wrench for birthday:
    7.5 Amp 1/2" Impact Wrench - PCE211 | PORTER CABLE
    I wanted a decent torque corded wrench, and this one had good reviews. Spun torqued lug nuts off the Prius, very easy. Bit of a handful, but meh.
    $130 CDN, can't complain: the high torque battery powered ones are cool, and more portable, but the prices are through the roof. And if you're in a garage with AC outlets, very simple.
    Montgomery and Salamander_King like this.
  18. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    I was going to ask you... "Is it your first cordless battery-operated power tool in your arsenal?" Then clicked your link, and realized it is corded. Of course, it is. ;)
  19. ChapmanF
    19,009
    Or working on a car with an inverter.
  20. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    Harbor Freight (a retail tool shop out here in the U.S.) has this:
    BAUER
    8.5 Amp Corded 1/2 In. Extreme Torque Impact Wrench
    Not sure about the Bauer brand, but it is 79.99. Harbor Freight has a good exchange policy as well.
