Mechanics: what are your most common tools?
Discussion in 'Gen 3 Prius Technical Discussion' started by PixelRogue, Sep 3, 2016.
Tags:
  1. Leadfoot J. McCoalroller
    8,293
    7,808
    Pennsylvania
    2018 Prius c
    overhearing a 6pt/12pt discussion between two bored maintenance engineers
  2. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Doesn’t most everyone have both 6 and 12, and how careful are we to choose between the two?
  3. frodoz737
    frodoz737 Top Wrench
    4,810
    2,562
    33
    Now this thread is funny.
  4. frodoz737
    4,810
    2,562
    33
    deleted double tap.
  5. ChapmanF
    19,055
    I did have some colleagues at $work chuckle to hear I'd been called Steven Hawking.
  6. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    Was the rationale for each argument the same?
  7. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    Did you see this interview with Hawking? It's one of the funniest videos I've seen in a while. The guy had a great sense of humor.
  8. Mendel Leisk
    42,376
    Was replacing a halogen head light bulb on daughter's Pilot yesterday; it's never easy. Owner's Manual says grasp the bulb, rotate 1/4 turn counterclockwise, pull out. Yeah right.
    First off it's a tall engine bay, a single step up a ladder is helpful, and I had that. Then it's really obscure, you can reach it with one hand, but just, and lordamighty it takes some oomph, to get that thing through the locking resistance, to turn and release. Same thing in reverse when installing the new one.
    I've a vague recollection of using adjustable wrench like this in the past, and of course that was the one tool I didn't bring. Anyway, for next time:
    edthefox5 and Raytheeagle like this.
  9. padroo
    padroo Senior Member
    2,763
    2,253
    I hope you didn't mess up your knuckles doing that job Mendel. Looks like it would be less painful giving blood to the Red Cross.:rolleyes:
    Mendel Leisk, edthefox5 and Fostel like this.
  10. Mendel Leisk
    42,376
    No, that's just a circulation issue. Happens every winter.
    edthefox5 likes this.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Apply lubrication to the bulb socket next time it will come right out.
  12. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Like the huge log as a work service. Kinda makes me homesick for Vermont.
  13. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Put some vasoline on the seal. it will go in easily, and when you need to remove it, it will also turn easily.
    Rebound, Fostel and Mendel Leisk like this.
  14. Zeppo Shanski
    Zeppo Shanski Active Member
    315
    193
    Chicagoland
    I've read lots of threads about maintenance noticing that many of you shade-tree mechanics are really big on proper torque.
    I don't work for or make any $$ from Harbor Freight. ... I'm just showing you a coupon deal.
    All drives ... $12 each.
  15. Mendel Leisk
    42,376
    Get all three!
  16. tonynap
    tonynap Member
    43
    38
    NY
    That would probably work on the light bulb as well.
  17. ASRDogman
    8,070
    4,092
    Not sure about that. You might want to use dielectric grease, that would be better.
  18. Mendel Leisk
    42,376
    I'm drawing a blank on google, so:
    I've got three pencil style tire pressure gauges:
    1. No-name 10-50 psi, hard to seat properly, purely for back up.
    2. PCL 10-120 psi, gauge a little cramped and hard to read, feels heavy/solid, had it for years, dependable.
    3. Milton 20-70 psi, recent purchase, easy to use, easy to read.
    I've been mainly using the Milton, and set my tires to 36 psi with it. The issue: if I read the pressure with no-name I get just shy of 32 psi, and with the PCL I get 34 psi.
    My preference is the Milton, just for the easy-of-use and readability, but I'd be curious to know how accurate it is. I wouldn't mind having add/subtract a couple of pounds fudge factor, if needed.
    Has anyone heard of a pressure gauge accuracy checking service? Maybe, for example, Costco's tire department mechanics might use one, could help? Just curious if anyone's got ideas.
  19. CR94
    CR94 Senior Member
    2,839
    1,244
    Northwestern S.C.
    There are such things as high-precision laboratory pressure gauge testers, which use weights on a piston. I used one when I tested tire pressure gauges years ago. Most digital gauges are reasonably accurate (although less convenient to use than a conventional pencil-style gauge, in my experience).
  20. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    Is that a 6 point or 12 point Crescent wrench? :D
    frodoz737 and Mendel Leisk like this.
