Melted extension cord socket
Discussion in 'Prime Plug-in Charging' started by bwilson4web, Apr 30, 2017.
  1. bisco
    52,861
    i switched parishes, just so i could make the trip in ev.:oops:
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    17 miles one way?
    go Athiest save the trip:D
    huskers likes this.
  3. bwilson4web
    16,537
    I "loaned" my 40A, L2 EVSE to Propst at 5 Points who put in a 50A circuit. So tonight:
    • Arrived with ~85% SOC.
    • Turned in Rx for me and my wife.
    • Bought "lady stuff" for my wife.
    • Picked up RX.
    • Headed home with 97% SOC.
    Propst is about 8 miles away and there are plenty of closer pharmacies and shops. But they don't have any compensation for this plug-in driver.
    jerrymildred likes this.
    52,861
    it's the final trip that has me concerned.
    Dudley1030, huskers and jerrymildred like this.
  5. priuscatprimeguy
    2,730
    2,640
    yup, we all die eventually
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    And then we find out for sure what's next. I wish you well, friend. Don't want to turn this into a religious debate. As @bisco said, it's that final trip that really matters. I always appreciate your comments here on PC.
    giora and bisco like this.
  7. priuscatprimeguy
    2,730
    2,640
    and yet "and then we find out for sure what's next" comment is a debate if you didn't want to turn this into a religious debate you should have not said anything.
  8. Trollbait
    12,831
    There's a difference between amps and watts. Then the hair dryer isn't likely on an extension cord.
    priuscatprimeguy likes this.
  9. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    1500 W hairdryer draws about 12.5 A @120 V, quite close...
  10. Rmay635703
    Rmay635703 Senior Member
    2,704
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    All my dryers are 1875 watt, 15 amp circuit is good for 15 amps, just not continuously.
  11. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    But what caused the high resistance? Loose contact? Foreign substance causing a poor connection? The root cause is whatever caused the high resistance. I like to use a very small smear of an anti-corrosion joint compound like Ox-Gard or equal on the contacts to chemically clean the contacts and lubricate them. Very small smear...the product is conductive and must not bridge from one contact to the next. And, of course, examine the connections by feel and vision, and junk any that aren't 100%. Some are bad from the factory. I got a 240 jolt from a brand new dryer cord with a wayward strand through the molded plug. Wowser! I was sick for a few hours.
    A $2.79 commercial grade 15 amp receptacle will do a better job longer than the usual 59ยข receptacle. A $16 hospital grade wiring device is great but not needed.
    But they mostly come with the same 15 amp plugs and connectors. For a 12 amp draw there is no reason to buy a #10 cord. A #14 portable cable has an ampacity rating of 18 amps when only two conductors are carrying current (that means single phase, not three phase). In three phase service the #14 cord has an ampacity rating of 15 amps. It's all about the heat; the portable cable is probably not wrapped in a 6" fiberglass overcoat like Romex inside a wall at home.
    #31 PT Guy, May 1, 2017
