MERGED: Toyota Announces Free NAV DVD Upgrade
Discussion in 'Gen 2 Prius Main Forum' started by Arizona Charlie, Nov 13, 2004.
  1. tag
    tag Senior Member
    2,526
    Chicago
    Have you actually compressed the file?
    I tried with WinRAR and gave up. At well over an hour, I hadn't even hit the 20% mark using the "best" mode.
  2. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    I see what I did wrong. I divided by 3KB, rather than 300KB. Doh! I figured I was off by at least a factor of 10.
  3. tag
    tag Senior Member
    2,526
    Chicago
    No biggie. I mean, what's a few hundred hours, more or less? :lol:
  4. MashedPotato
    MashedPotato New Member
    17
    Inland Empire, CA
    Yes. I don't recall how long it took, but I let it run overnight.
  5. tag
    tag Senior Member
    2,526
    Chicago
    I'll try that later tonight.
    BTW, which mode did you use. I noticed WinRAR has several and assumed "best" would provide the greatest amount of compression.
  6. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I have a gzipped version at about 3.5 gb - made an ISO (dd ripped in linux) shortly after I got it. Not sure if the NAV box could read the DL disk though if you were to burn one. And I 'm not in a posi tion to pop $20 on a DVD+R9 to find out.
  7. tag
    tag Senior Member
    2,526
    Chicago
    I ran PkZip and the zipped file came out about the same size and it took considerably less time than WinRAR (a little over an hour).
    $20 for a DVD+R9? You might want to check Best Buy. I just picked up a 3-pack a few days ago. It was around $30 ($10/each). Still, waaaay too much dough to be doing, well, a lot of anything. :wink:
  8. TCD
    TCD Junior Member
    97
    Northern, NV
    Hi Folks,
    I upgraded to 4.2 yesterday (the dealer claims this is the latest...). In any case, 4.2 has much more detail for northern NV!
    YMMV
  9. kmbell
    kmbell New Member
    Northern California
    I received the upgrade about a week ago. Tonight is the first time I have tried to use it. It is FAR WORSE in terms of operation. Am I the only one noticing? From my driveway and for about 3 blocks (3 different streets), it did not notice I was on the route and would not give verbal instructions. Since I drive this 3 blocks all the time, I know for a fact that this is a new and worse behavior. Then, I failed to turn when Priuscilla instructed me to do so, and it NEVER recalculated the route. I had to figure out how to get back to the wrong turn, which took several minutes. I have the NAV system because I am visually impaired and cannot read street signs. I NEED the voice instructions to work and the route to recalculate. Has anyone else had a problem? Can I downgrade? Who should I call? I am going in for the brake light recall tomorrow, so I will ask Toyota. I have a bad feeling I'm just hosed... I could not locate any complaints on this forum either.
  10. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I've not tested the reroute on the new disk. My 1 experience, yesterday, was quite good and the accuracy was dead on.
    I don't understand why the re-route and such wouldn't work...that should not be a DVD issue but rather something programmed into the NAV system itself..I wouldn't think it would be altered by the data disk.
    You should probably check your set-up screen for the NAV system...it is possible it is reprogrammed in someway that has re-route shut off or something.
    Again, not recognizing where you were seems very odd, and not an issue with the disk but with the NAV computer itself. Have you retested this, tried to repeat it in other areas, etc?
    Also, if I'm not mistaken, most state laws require you to have adequate vision to read street signs as many of them have safety information and warnings on them. If your vision is so bad that you cannot read them you need improved vision correction or you need to stop driving on public streets lest your impaired vision doesn't allow you to see the small child in the street, or a motor bike or a jogger.
  11. kmbell
    kmbell New Member
    Northern California
    OK, I know this isn't part of the thread proper, but let me address the vision thing first because most people are not aware of the laws. They vary from state to state, but it is not a problem for me to drive and my vision is not even close to the legal limit that would prevent me from driving legally. I cannot read street signs but can see highway signs just fine. There are many people that are able to drive legally and safely without 20/20 vision. My vision cannot be further corrected, and the state of CA, as well as all of my doctors, are very aware of my current vision and they provide written information to the DMV stating the terms of my vision, etc. This is the vision I have always had. If it were a new condition I am not sure I would want to drive, but I am a safe driver and am able to see cars, pedestrians, etc. without a problem. I can see street signs and can sometimes read them, but not while driving (since I don't have time to look that carefully). I have had a legal license in 3 states and have been driving for 28 years without an accident.
    OK, back to the real subject - I will be testing the problem more this week and will schedule a service appt with Toyota. They want the car all day and will give me a loaner. I notice that the NAV system is more accurate in determining arrival to destination. It also reroutes correctly in the middle of the route but has this problem at the endpoint. I haven't had the opportunity to fine tune the testing, but I will do that before scheduling the appointment. I am hoping to find a route near the Toyota place that will demonstrate the problem.
  12. kkister1492
    kkister1492 New Member
    355
    Fremont, CA
    I just got my update today 4.1 to 4.2. I had bee really happy with 4.1 and thought that 4.2 would be evern better. Well, it has lost it's mind. I live in a geted community with no connecting streets except for the gate. 4.1 knew that and directed my correctly. 4.2 would have me going through all kinds of streets that don't connect (not even the same names) and through fences or walls. This is as bad as MapQuest and YahooMaps. I had been so proud of how smart my car was before..... Isn't there a way to 'teach' it the right way?
    I have a call into the dealer. Might have to down grade. I was not given the DVDs so I'll have to go in.
