Met a 10,000 mi/month, Prius Prime owner
Discussion in 'Prime Main Forum (2017-2022)' started by bwilson4web, Aug 20, 2019.
  1. Mendel Leisk
    41,479
    My 2010 Owner's Manual says 0W20. No distinctions regarding synthetic, though I'd assume all 0W20 is synth.
    (page 560)
  2. Tideland Prius
    16,559
    Yup. I was sold either oil depending on where I got my car serviced. Alberta? 0W20. BC? 5W20. Prices are different with the 5W20 being cheaper.
    However, that option for 5W20 isn’t available for later MY even though it’s the same engine.
  3. Trollbait
    12,543
    For two of the three years that Lincoln pick up was available, the oil change interval was 5000 miles.
    For 2008, perhaps the increase to 7500 was for marketing, or maybe the oil passages were enlarged, or the specified oil was better. I do know that when Ford switched to 5w20 oil, they back certified many engines for it on the road, but not all for technical reasons.
    Toyota paid for those sludgy engines.
    What exactly was the failure?
    The only blown engine I'm familiar with happened because of problems with the cooling system.
    Of maintenance items to do early because of potential engine destruction, I'd have timing belts at the top of the list.
    Yeah, 0w- isn't possible without at least some actual synthetic oil mixed in.
    Raytheeagle likes this.
  4. nssdiver
    nssdiver Me digging' life
    Syracuse, NY
    Four Touring
    IMG_7129.JPG IMG_5696.JPG I'm kinda floored at the paranoia here of not using even moderately extended oil change intervals.
    I change the oil on my '07 Prius 1x/year whether it needs it or not.
    It's coming up on 330,000 miles - do the math.
    (Actually, there were a number of years I drove >>30,000 miles/year.)
    And it does not burn any oil in the conventional sense.
    And after this little addition, it appears to use no oil at all anymore.
    Had my valve cover gasket replaced while changing out my PCV valve recently (@ ~300kmi) by an ex Honda Master Mechanic and he was surprised by the minimal amount of wear after becoming aware of my oil change interval. IMG_7129.JPG View attachment 177271 View attachment 177271
    benagi, Raytheeagle and Trollbait like this.
  5. avongil
    avongil Member
    67
    56
    Easton, PA
    Wow. That is impressive.
    It is pretty mind boggling how reliable the 1.8l engine is.
    The oil catch is also a great idea.
  6. meeder
    meeder Active Member
    239
    163
    Doesburg, The Netherlands
    The engine is very reliable since it is never pushed to the limit under high load. Sure it revs high but that engine was designed to do that.
  7. avongil
    avongil Member
    67
    56
    Easton, PA
    Still 30K oil changes are impressive. I must say the picture and the oil change schedule has changed my mind. I will "push" it off to 10K.
  8. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    European engines require better oil than is commonly available here in North America. It costs more and it lasts longer. Look at the ACEA specs vs. SAE & ILSAC specs, although the gap is narrowing.
    The sump capacity needs to be factored into the oil drain intervals. A larger sump lets the oil sit there longer where it's not being stressed in the bearings. Our tiny 1.8 liter engine has a relatively large sump. Some Porsche engines have a long oil drain interval and a 10 quart sump, for example.
    Synthetic oil, even the Group 3 base oil faux-synthetic we usually buy, oxidizes at a slower rate than conventional oils made from Group 2 base oil. This adds to the oil life.
  9. Witness
    Witness Active Member
    115
    117
    San Francisco Bay Area
    Yea, I drive the same per month. I guess it's not too crazy considering anyone that bought a Prime has high mileage. At 10k, that is something.
    iPhone ?
