Metal accessory to protect entry sill plastic
Discussion in 'Gen 5 Prius Accessories and Modifications' started by DecorahDave, Nov 1, 2023.
  1. DecorahDave
    DecorahDave Member
    2023 Prius
    I think I saw a piece of metal to mount over the plastic raised part of the drivers door entryway. My Toyota dealer can't find anything. I've got a clear roll of "helicopter tape" that I'm going to try. My plan is to clean the surface with Prep All to remove any oil or anything that might make it not stick. Just measured the thickness of the tape at 0.016". Will keep you posted. But if there is an accessory, I still want to know about it. Seems it was in the $200 range.
  2. Jim Call
    Jim Call Active Member
    107
    115
    Asheville
    2023 Prius
    Accessory available from my dealership. Yep, $200 for all 4 door sills. The ones for the rear doors are pretty useless however, but the front ones are pretty effective and look good.
  3. DecorahDave
    DecorahDave Member
    2023 Prius
    Those look nice but they are not what I was talking about. I need to protect the plastic ridge betweer the floor and the metal. My feet drag on that plastic because it is highest part of the area. I just got a 4" wide piece of clear plastic and will take some pictures as soon as get it installed. Thanks for the suggestion.
  4. Kenny94945
    Kenny94945 Active Member
    864
    439
    Sausalito
    2016 Prius v wagon
    I've seen aftermarket hard clear plastic cover for that sill panel on Corvettes.
    Never seen those for Prius.
    OP's idea on clear tape may work.
    Perhaps, another option for appearance, remove the panel (both sides) and completely upholster with Alcantara?
  5. wrtboy168
    wrtboy168 Member
    70
    29
    Northern California, USA
    2024 Prius
    perhaps this is an option. made from stainless steel and it's also offered in black.
  6. Mendel Leisk
    42,347
    They're not illuminated anymore? For the best. Our '10 came with illuminated door sills (on the front doors, similar but unlit in the rear), and right from the get-go I thought it was silly. And just one more thing to run the 12 volt down. About on par with auto-folding mirrors.
    Still there's the question: why the hell should you have to pay extra for these little bits. Why not make them standard, and practical/durable. Rhetorical que$tion, I know...
  7. Blackat
    Blackat Active Member
    488
    356
    Colorado
    2023 Prius
    Limited AWD-e
    Where did you find those?
    NorCaGuy likes this.
  8. wrtboy168
    wrtboy168 Member
    70
    29
    2024 Prius
    @Blackat , found it on aliexpress. use keywords '2023 prius threshold' with the search. i find the shipping a bit much hence hoping to find other sellers with better prices.
    #8 wrtboy168, Jan 21, 2024
    Blackat likes this.
