Method to stop having HVAC be in ECO mode automatically?
Discussion in 'Gen 4 Prius Main Forum' started by Mambo Dave, Mar 13, 2020.
  1. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    Heya all,
    I think I may have hit some setting when I first got the car to try ECO mode on the HVAC, but it just isn't working.
    Anywhere from six to twenty episodes of starting the engine per day, and I'm getting tired of only noticing the ECON mode is back on after sweating - again. It just can't keep up with the heat, or what it takes to cool me off so that I don't sweat.
    I thought there was a setting in the car's menu, but haven't been able to find it. At this rate I'm going to wear out the ECO button before the car has 60k miles on it. It's also making me quite unhappy with the car. But I feel there is a fix to this as I searched the forums as best I could, and don't read others complaining of it always being on. Being weak, yes, but not always being on.
  2. booke02
    booke02 Active Member
    391
    415
    Israel
    I never have this problem, but I set if from the multi-function display.
    Perhaps there is a "feature" that it doesn't save settings made using the HVAC controls - so try setting it from the display.
    Mambo Dave likes this.
  3. Mambo Dave
    641
    307
    2019 Prius
    L Eco
    Thank you - perhaps that's where I set it to try ECO mode? I can't even remember if my L Eco has HVAC control on the infotainment section.
    Edit: just tried it - only one HVAC option there, and it has to do with having the AC on or not with the AUto feature or something like that.
    #3 Mambo Dave, Mar 13, 2020
  4. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    Not sure if it's the same (as the buttons are slightly different here in the UK), but every time you select the Drive Mode to Eco, it'll put the aircon in ECO mode too.
    You can configure this behaviour using the Carista app and an OBDII dongle, as it annoyed me too.
    That being said, if I don't play with the Drive Mode setting, and just keep it in Eco mode all the time and not ever select Normal or whatever the red one is called, then it does seem to remember the non-Eco setting on the aircon.
    kithmo and alanclarkeau like this.
  5. Mambo Dave
    641
    307
    2019 Prius
    L Eco
    Oh My! I bet that's what it is!
    I've been driving in the Eco drive mode for a while, I wonder if that's what it is! Thank you! I'll try switching it.
    I rather like the modulation of the accelerator pedal in Eco/Econ mode, but if that's what it takes to have my AC ready for me, then that's what it takes. I may look into the app and a dongle. Sounds fun to configure a car (or at least have the choices to do so).
  6. Mambo Dave
    641
    307
    2019 Prius
    L Eco
    You nailed it - THANK YOU!
    Just took the car to lunch. Once I was out at a traffic light I remembered to try putting it into 'Normal' drive mode. When I did so, the ECO HVAC mode that was on turned itself off.
    After lunch, it was so nice to have my AC back on again. 81 degrees out there, but with the sun coming in the windows it feels much hotter when getting back in the car. Not having the ECO HVAC mode on helps cool it down inside faster.
  7. The Professor
    598
    809
    UK
    Excel
    They're not permanently tied together on mine. Entering Eco drive mode does set the HVAC back to Eco mode too, but if I then set the HVAC to normal or "fast" mode it remembers that setting, even if the drive mode remains in Eco. On my car, there's an Auto button on the HVAC controls. Every press cycles through Eco Auto, Auto, and Auto Fast (or something like that). So if I want Eco drive mode, I just press the Drive mode until it's on Eco, then press the Auto button on the climate control to kick the HVAC out of Eco mode (or at least I think that's what I did before I configured it with Carista).
    kithmo, alanclarkeau and Mambo Dave like this.
  8. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Not sure they have the HVAC Auto button cycle feature in the US.
    alanclarkeau likes this.
  9. Tideland Prius
    16,632
    We don’t.
    alanclarkeau and kithmo like this.
  10. The Professor
    598
    809
    UK
    Excel
    Well that's a bit rubbish. You guys are missing out!
  11. Tideland Prius
    16,632
    What does that feature do? (We also don’t have dual-zone).
    Safe to assume Eco Auto does the same as our “Eco Heat/Cool” button? Which means Auto Fast is the new/different feature?
  12. The Professor
    598
    809
    UK
    Excel
    Pressing the button activates Auto mode, which means the car decides on the fan speed and air flow direction, and the user just dials in the temperature they want. Repeated presses cycle through Auto Fast (faster fan speed), Auto (normal fan speed), and Auto Eco (normal/slow fan speed and air con in some kind of economical mode).
    Tideland Prius and alanclarkeau like this.
  13. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Fast just seems to keep the ICE on longer for quicker warm up.
  14. Tideland Prius
    16,632
    Ahh ok. Thanks!
