MFD damaged by clay....
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by tony g, Apr 26, 2009.
  1. Qlara
    Qlara New Member
    488
    Cool! A creative problem was rectified by a creative solution.....it's a win-win.
    Grandma should be happy! :D
  2. a_gray_prius
    2,927
    783
    IL
    To play Devil's Advocate, there is also oil on your skin that can end up on the MFD screen. If oils could potentially damage the screen, shouldn't that fail some sort of engineering/design testing?
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Absolutely. Oil, dirt, and skin buildup on touch screens is a problem. The screens are designed for human oils, but are not necessarily resistant to other oils and solvents. That's why they come with a warning about cleaning methods and solutions.
    Tom
  4. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    I'm still using the ice pick for my laptop.
  5. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    OK, off topic but YOU started it! :D
    One of my favorite punch card stories is from Hughes Electronics in the early days of communication satellites. Weight was a critical factor in those early satellites, so the weights engineer pulled considerable weight on the program (pun intended). One day he showed up in the software department and wanted to know how much the software on the satellite weighed. A programmer told him it didn't weigh anything. Angrily he picked up a deck of punch cards. "This is software," he said. "What does it weigh?" The quick thinking programmer said, "Oh, you think the software is the cards, right?" "That's right!" the weights guy said. "Well, you're wrong," the programmer said. "The software is the holes in the cards. Those holes don't weigh a thing!" "Oh....OK then!" the weights guy said and left, never to be seen again in the software department.
  6. qbee42
    18,058
    3,081
    Northern Michigan
    Silly story. Probably true, knowing some engineers.
    You know what I miss about punch cards and paper tape? The chad. Especially paper tape chad. It had a nasty oiliness to it. Chad was indispensable for office jokes: filling brief cases, umbrellas, etc. :D
    Tom
  7. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    If you're using Vista, then it's recommended.
  8. Qlara
    Qlara New Member
    488
    Too bad....icepick is not part of the bundles when buying a Vista laptop....only junk wares are included.
  9. bredekamp
    bredekamp Member
    569
    Somerset West, South Africa
    The same reason I don't stick stuff to the LCD monitor I'm using now. It'll damage the screen.
  10. dwdean
    dwdean Member
    377
    South Florida
    While I understand the potential for office humor in the chad, some of us living in Florida (and probably the rest of the nation) don't remember chads with such fondness....
  11. qbee42
    18,058
    3,081
    Northern Michigan
    I can tell you with certainty, when my office mate opened his umbrella, there was very little hanging chad, except that hanging in his hair. :D
    tom
  12. hill
    9,039
    You mean I'm not supposed to use gasoline to clean the MFD ?? Right ... next thing you'll say is that I can't use brake fluid to shine up the paint :rolleyes: (now watch & see how many folks go out & try it)
  13. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Did you by any chance snap a picture and could scan it and post here? :)
  14. qbee42
    18,058
    3,081
    Northern Michigan
    Alas, no photo.
    Tom
  15. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    MFD failure due to objects placed in front
    In today's (May 9th) Seattle Times, Tom and Ray Magliozzi (Click and Clack) discuss a complaint from a grandma whose MFD (2006) failed after she placed some clay figurines made by her grand kids, on the ledge in front of the screen. Tom and Ray surmised that clay, having some moisture content, may have oozed enough moisture into the screen box to cause a failure. They also thought it possible that the figurines may have been placing a constant pressure on one or more of the touch buttons, causing the switch to be continually "on", and perhaps overheating.
    Her dealer said it could cost anywhere from 800 to 4000 bucks. T&R thought that the price range depended on how much of the system was damaged. The MFD screen is an interface between driver and assorted computers, and if only the screen was damaged, the cost would be towards the 800 buck level, but if the damage extended to the computer circuitry, it could be pretty expensive.
    Bob
  16. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Re: MFD failure due to objects placed in front
    We had a thread on this already with long discussion...but I'll be darned if I can find the thing now. If someone does post a link to the original thread and I'll close this one.
  17. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  18. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    The net conclusion, if you do not want to destroy your MFD,
    DON'T FRAK WITH IT!!!
    NO STICKERS, OBJECT DE'ART, SUCTION CUPS FOR DEVICES, CONDUIT IN THE BACK HATCH RESTING ON THE DASH, NOTHING!!!
    Does that clear up any confusion???
  19. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    Dealer would replace the whole MFD, for which the MSRP is $6,741.13. Champion ToyotaWorld will sell it to you for $5,123.26.
    A salvage part may well be cheaper, but don't expect a dealer to do a Hobbit and just replace the screen itself.
  20. dogfriend
    7,512
    1,191
    Carmichael, CA
    Its probably a bad idea to try to clean the screen using clay. :madgrin:
