MFD died without warning- next steps?
Discussion in 'Gen 3 Prius Audio and Electronics' started by Pluggo, Oct 12, 2022.
  1. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    My MFD head unit worked perfectly until it went dead last week. That is to say, there is no light on the screen, no sound from the JBL speakers, and no reaction to the knobs or buttons. Basically, no more backup camera, radio, DVD, navigation or Bluetooth phone interface. I checked all the fuses (everything under 25 amps) on a test meter and I pulled and re-seated all the plugs in the back. The local dealer and Best Buy both said they were unable to bench-test the unit. Is there anything left to do before deciding on a replacement? Does anyone have a favorite aftermarket unit they want to recommend?
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Multi function display is separate t from the head unit. You can’t lump both together as they are not the same thing
  3. Pluggo
    608
    534
    OK, @Grit It's nice to see you again. Let me try to restate the question in colloquial terms: What is the next step when the radio don't work and the screen is black? Thanks in advance for all helpful answers.
  4. Mendel Leisk
    42,345
    This is aftermarket? You mention Best Buy.
  5. Pluggo
    608
    534
    No, it's original. I was just hoping Best Buy or Toyota would be equipped to test it so that I could be sure the car's wiring was not the problem. They are not so equipped.
