MFD issues on '04/'05 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by efusco, Jun 19, 2007.
  1. patsparks
    10,664
    569
    Adelaide South Australia
    That's why I paid a tech $25 to do the soldering for me. He re-flowed all the pins under a microscope.
  2. TreffEdwards
    TreffEdwards Hybrid Family
    30
    Houston, TX Des Moines, IA
    So My best friend has a 2004 Prius w/ 175k on it, his has been acting really odd just like ya'll have stated. So I am going to help him out and *try* hobbits fix.. If not I told him to just buy one off Ebay! :) I have a 2005 w/119k and no problems.
  3. patsparks
    10,664
    569
    Good luck Jeff, not that you will need luck just a bit of skill. Mine is still going strong.
  4. frenchie
    frenchie Member
    150
    48
    France, not far from PARIS
    Re: MFD issues on '04/'05 Prius
    THANK YOU Hobbit
    this morning, we had a quite interesting surgery on the mfd of a 2004 prius.
    everything seems ok now.
    Panne Ecran / Clim / Radio - Forum Prius Touring Club
    FYI the cost of the repair was around 3000$ if you listen to the local toy shop.
    when you come to france let me know...
  5. TreffEdwards
    30
    Finally finished it :) Works like a charm! I was battling doing my leather and working on this, plus my normal crap. :) Instructions and info couldnt have been better on here. Thanks ya'll. My friend is very happy now that his screen works. lol
  6. patsparks
    10,664
    569
    Good on ya Jeff, well done.
  7. Tideland Prius
    16,680
    Hmm, so my MFD is acting up again. Radio and A/C don't work. Energy Monitor doesn't show the arrows but the wheels move.
  8. patsparks
    10,664
    569
    Time to resolder.
    I used a specialist and I expect my repair to last a long time.
    If it plays up again I'll just pull it out and fix it again.
  9. Tideland Prius
    16,680
    resolder? you mean the motherboard? The dealer told me my dad to replace the motherboard for Cdn$1,200. Galaxee said the symptoms displayed are not indicative of the classic MFD failure. I'm so confused.
  10. patsparks
    10,664
    569
    That sounds like what mine did. Have you read the MFD thread by Hobbit?
    Mine the radio would go off or when the MFD was acting up the radio was on but if I pressed the audio button the screen says audio off and when you press the Climate button a message says the AC signal isn't available or something like that.
    Either way I'd re-solder the plug to the board as in Hobbit's instructions, there is little to lose and a lot to gain.
  11. Tideland Prius
    16,680
    The first time it happened, I had the A/C not connected or sth like that. I fixed it by playing around with the DICE. This time, there are no messages so that's why it might not be the classic MFD failure. I'm gonna try and unplug the DICE again. I'm not home with the Prius so i'll have to do so when I go home during Easter.
  12. patsparks
    10,664
    569
    That night be the fix too.
    The more I hear about these add ons to the MFD the more they scare me.
  13. Tideland Prius
    16,680
    Well nothing I can do now. I'll update when I go home and try out the various suggestions.
    Well if you don't have the DICE, that's one less factor lol.
  14. BerkshirePrius
    BerkshirePrius New Member
    121
    Berkshire, NY
    My dice will crash my MFD occasionally, just unplug and reboot, then all is good.
  15. SanH
    SanH New Member
    Ontario, Canada
    Can anyone tell me if they have purchased the refurbished unit for the display unit in the 2004 Prius if they have had any problems with the refurbished unit or does it work fine? I have an opportunity to purchase a unit at close to $1500 plus Toyota labour to install it.
  16. Tideland Prius
    16,680
    I've had the DICE crash itself several times (i.e. nothing will come out of the speakers even though the iPod is playing). Unplug, reboot the car, plug it back in and it works.
    Ok so my brother decided that he'll try the repair rather than wait. He unplugged the DICE and plugged it back in (he hasn't got back to me whether he unplugged the DICE unit fro the radio or unplugged the wire to/from the radio from the control box.) and now it works :confused:
  17. maseace
    maseace Prius enthusiast
    191
    Poulsbo, WA
    $1500 is way too much. I got a 2005 display (revised part number) on eBay for just over $100 that is working fine. It's pretty easy to install yourself. All you need is a philips screwdriver and a 10mm socket.
  18. SanH
    SanH New Member
    Ontario, Canada
    I have an opportunity to get a refurnbished unit Scott. Did anyone answer you back if they are dependable?
  19. shortzrules
    shortzrules New Member
    Spokane
    We had to have our MFD replaced last April. Cost for the refurb was $450 I believe the total bill was $650.
    So far the refurb. is working like a champ. Still very ticked off that such an expensive part was so flawed though.
  20. SanH
    SanH New Member
    Ontario, Canada
    Thanks for the info. Its much appreciated. In Canada that is the price, so I'm going to go ahead as a new one is $3900 in Canada.
