MFD issues on '04/'05 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by efusco, Jun 19, 2007.
  1. Patrick Wong
    18,210
    6,517
    I had the MFD in my 2004 replaced under warranty, and assume that a refurb unit was installed. It has worked fine over the last couple of years (with >50K miles logged during that time.)
  2. Tideland Prius
    16,672
    Hmm, we were quoted $1,200 for the motherboard!
  3. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    One thing that bugs me here is how often people say "got one off
    Ebay", which immediately raises the question of who they got it
    FROM, and where THEY obtained it originally. Sure, it's one thing
    to be happy to get a working unit, slap it in, and move on, but
    it would really help the community to know the lineage of where
    these things are coming from, whether they're the revision G units
    that in theory have the better connectors, etc etc. The loss
    of easy-to-obtain tracking detail on this issue is distressing.
    _H*
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Re: MFD issues on '04/'05 Prius
    H
    I share your frustration, but I think you have to accept a lot of people just do not give a s*** about that level of detail, FMECA, etc
    Something tells me in another 2-4 years we're going to be seeing more 2004-2006 vintage Prius with dead MFD's, dead Combination Meters, and then folks will suddenly want to pay attention to issues like connector corrosion, connector quality, etc.
    Consider the enormous issues with BGA's when the solder change was pushed through, with no real investigation of long term issues
    jay
  5. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    replacements are new units if replaced under factory warranty. they are refurb if replaced under extended warranty. some dealerships will try to sell a customer a new unit if they're out of warranty, but this is bullshit. you can get a refurb unit if you're paying out of pocket.
  6. Tideland Prius
    16,672
    Then what's the point of an extended warranty? You're paying an extra $2k (give or take depending on length and mileage) and you're not treated the same as someone in the new car warranty?
  7. galaxee
    9,810
    471
    MD
    the refurb unit still costs a chunk of cash, and that cost is covered by the EW. probably a cost-cutting measure.
  8. Tideland Prius
    16,672
    ohh... but there's still an out-of-pocket expense?
  9. hobbit
    4,089
    469
    Bahstahn
    Yeah, I'm going to treasure all the 60/40 I have left until they
    pry it out of my cold dead fingers.
    _H*
  10. patsparks
    10,664
    569
    Adelaide South Australia
    Ouch, refurbished cost a lot more than just fixed the one you have. My repair cost $25AU plus my own labour to remove/refit.
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    Sooooooooooooooooo looks like somebody was wise enough to rathole a bunch of that evil 60/40. Hmmmm
    I know who I'll be visiting with next time in "Bahstan"
  12. KenP
    KenP Junior Member
    Reporting in that my 2004 Prius with 55289 miles has the MFD issue that has been described in this thread. First occurance 15MAY2009. I live in Florida.
    Car out of warranty and I didn't buy the extended warranty. I have never had any service problems with the car. I Have done all the routine maintenance and factory recalls.
    Toyota should pay for this repair out of warranty since it was a known defect back in 2005, but from what I read they are not doing it unless the claim is escalated and then maybe not full coverage.
    I'm going the eBay route to get a refurbished unit and then send mine back to the eBay seller.
  13. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    I have a 04 early model and hope i dont have the same issues at almost 60K now :)
  14. hybridmel
    hybridmel Junior Member
    36
    Just out of curiosity, is this a detectable issue?
    We are hoping to be able to take the Prius I am looking at to a mechanic to have it looked at for an inspection.
    Would a faulty MFD be something a qualified mechanic could pick up on, even if it is not in the severe stages?
    I cannot afford a $1,000 repair right off the bat, and the MFD was one thing that was definitely concerning to me, especially if the 05's were prone to it.
    P.S. How do I know if it was an early or late 05 model?
  15. oxnardprof
    oxnardprof Member
    250
    17
    Oxnard, CA
    I just had the problem on my 2004 Prius. The fault was obvious, if you drove around a little bit. In my case, it often acted up on starting the car.
    The problem showed up at 86,000 miles or so. Fortunately for me I have the extended warranty.
    I took the car to Ventura Toyota (where I purchased the car) on May 13th. They inspected the car, verified the MFD problem, and filed a claim on the warranty. Two days later they already had the part. I brought the car in today (May 20th) and the car was fixed in about an hour and a half. The service person helped me reestablish the bluetooth connection to my phone.
    The cost of the repair (refurbished MFD) would have been $768, but of course I paid nothing.
    So, the experience of replacing the unit was as painless as it could be, at lest at Ventura Toyota. Of course, the extended warranty helped, even though I am still 'down' since I think the warranty cost more than the repair.
    Edit: The MFD retained memory of current tank fuel consumption and my navigational data.
  16. patsparks
    10,664
    569
    Why not read the thread, print out the instructions for the fix and take the car to a radio installer who may be able to affect the repair for the cost of about 1 or 2 hours labour?
    I took my MFD out myself in about half an hour, dismantled it using Hobbit's instructions then had an electronics tech do the soldering at a total out of pocket cost of $25.00 because that was his minimum charge, then put it back together myself.
    Not had an issue since.
    Be brave, have a go.
  17. KenP
    KenP Junior Member
    I installed the refurbished unit from autobeyours.com via eBay today 30MAY2009 without incident. It took me about 1 hour. Someone experienced in taking about the dash could probably of done it in 15 minutes.
    So it cost me $299 + $25 shipping + $10 to ship old unit back = $334
    Plus my hour of labor $0.02 :)
    ...KenP
  18. patsparks
    10,664
    569
    How does that compare to my cost of $25 to have the solder joints re-flowed plus just a little more time to pull the MFD display apart and assemble it.
  19. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Look in the driver's side door jamb and find the build date for your Prius. It will specify the month and year of your build date.
  20. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    If any in the California Bay Area have this issue I'd be happy to look at the intructions on Hobbit's page. Our tech guy at the stereo shop is great with a soldering iron. I'd hate to see PC'ers get shafted for $1,000 when they could spend less than $100 to have the joints/tracers resoldered. :(
